SSpeed Posted December 29, 2013 Share Posted December 29, 2013 For the members here that run at Bandi, what time and speeds have you run and what mods (especially turbo) did you have at the time? Long story short, going to tear in to my build and make some changes. I feel 12s at altitude is an unaccomplished goal that I want to shoot for. The closest I've gotten is 13.1@105 in the Talon before I sold it. If I have to be honest, that is nagging me. I was contemplating a GT3076r, it has good dyno numbers and hits like a hammer, but I know of a few people with lackluster 1/4 results with it. Presently I only have one good run on the 16g, a 100deg day pump gas run at a low 14. I hotlapped it and welded the clutch to the flywheel on the next pass. Even on a cool day it doesn't feel 12s capable as is. My thoughts: * Switch to e85 and ID1000s * Contemplate new turbo By Legend's old turbo thread I don't know if an HTA68 would be a cost-effective upgrade. http://legacygt.com/forums/showthread.php/bnr-hta68-thread-140671.html?t=140671&highlight=legend+hta68 Link to comment Share on other sites More sharing options...
tommypenguin Posted January 2, 2014 Share Posted January 2, 2014 On HTA68 with full bolt ons, e85 tune, possibly winter tires, with an IIRC 2.4 0-60ft time I ran a 13.7. (It was my first time at the strip) I can guarantee if someone who was experienced at the strip was driving my car with better rubber and clutch/flywheel they would have easily been able to hit high 12s if not mid 12s. Link to comment Share on other sites More sharing options...
SSpeed Posted January 2, 2014 Author Share Posted January 2, 2014 Thanks man, yeah fast times are often dependent on the 60 ft time whereas the traps are your power indicator. I think raping the car on launch could get a 1.7 60 ft for sure. That alone could drop a second off of your time. I worry about the transmission and clutch too much now though. That's sort of cutting it close for my goals. When I ran a 13.1@105 in a past life I felt like I was raping the car terribly (5500 rpm clutch drop lined up in the groove, lowered tire pressures, 1.7 60 ft time) just to get super close to a 12 and couldn't eek out that last .2 seconds with driving. Do you have the stock clutch? Do you have a porky Limited or is it the lighter non-Limited? What was your trap speed? 7cm or 8cm HTA68? What exhaust, intake and intercooler? 5 or 6 speed? Any suspension mods? Sorry for all the questions. If I go through the trouble of changing my setup I want to bury myself deep in to the 12s without having to tweak every little thing to try and eek that last bit out of it. Link to comment Share on other sites More sharing options...
tommypenguin Posted January 3, 2014 Share Posted January 3, 2014 I was running the stock clutch at the time but swapped out afterward. Had a Ltd, don't recall my trap speed. It was 7cm housing IIRC. Below is a copy and paste of my mod list, I believe in my build thread I documented my experience at the strip in more detail. Its been 4 and a 1/2 years since I ran my LGT there, and 4 years now since I owned my LGT. Engine: FP 68HTA running 21psi peak at a mile high WBR FMIC Perrin Catless Downpipe Perrin Catback Exhaust Perrin Modified 824cc Injectors Perrin Inlet Perrin EBCS Maddad EL Header IAG 3 bolt Uppipe flanged for EWG rerouted to DP Tial 38mm WG V band Walbro FP AVO CAI GFB BPV w/ Soft Spring Tactrix OpenPort 2.0 cable One Step colder plugs Infamous OS Pro-Tuned on E85 Suspension/Brakes Cobb Front Sway Bar Cobb Rear Sway Bar Kartboy Front Endlinks Karboy Rear Endlinks Sti front Strut Bar Ebay Rear Strut Bar Racing Brake 2 piece Front Slotted Rotors Racing Brake Rear Slotted Rotors Hawk Street Pads Drivetrain: ACT HD Clutch 06 WRX Flywheel Group-N Engine Mounts Group-N Tranny Mount Link to comment Share on other sites More sharing options...
