Brake disk swap
krot84
Posted
Hey guys, don't know if this subject was talked about before, however i have some questions.
Lets say i swap my front disks into the gt ones, the disk will fit because both of the cars have 17" rims (I don't talk about the spec b but the regular GT), Will i my calipers fit the gt disks? Or I'll have to replace them as well?
Posted
I am not a pro here but I was thinking of improving my breaking also - I looked at a couple of sites like KNS Brakes and Top Brakes. They have all the upgrades you could ask for including a Brembo Big Brake upgrade. I also have been checking here and many suggest the Porterfield R4-S pads - for the Legacy - depending on the age of your current rotors there are many different styles of them also -
Posted
Jack, i'm not looking for a fancy aftermarket upgrade, all i want is to use the oem GT's if that's possible.
I know that i can easily spend $1000 on new kit but it won't make much difference because my car is NA.
Posted
So you have a 08 Legacy 2.5i?
If I understand your question correctly, no your 2.5i calipers will NOT fit over the LGT rotors. You will have to get LGT calipers.
-Nick
Posted
The caliper mount bracket may also be different. You may be able to get some swapability info on oppsedforces.com Which list SUbaru part numbers for varius models.
