Fire Away Posted December 18, 2013 Share Posted December 18, 2013 So I am in the middle of a timing belt change and I have two issues. One minor the other hopefully minor. The kit I got has the wrong tensioner. No biggie I can just do the pully. The other issue, I had the timing marks lined up, went in the back yard to put the tensioner in a vice, and came back to find the driver side timing mark at 6 o clock instead of 12 o clock. Which way should I turn the driver side cam pully to properly align it? Link to comment Share on other sites More sharing options...
Fire Away Posted December 18, 2013 Author Share Posted December 18, 2013 Now that I go and look at it again, the crank pulley doesn't have a visible notch on it either, just a red mark that is pointed at about 2 o clock. I guess I would be fine turning the driver side cam pulley clockwise until it is straight up, installing everything, and rotating the engine until I can see the notch on the crank pulley. Does that sound like a valid plan? The last thing I want is bent valves. http://i.imgur.com/QCAaaaP.jpg Link to comment Share on other sites More sharing options...
reeg420 Posted December 18, 2013 Share Posted December 18, 2013 When I had done a timing belt on my 97 gt the belt itself had marks on it that corresponded to the marks on the pulleys. Just a thought. Even if you aren't completely sure crank the motor by hand on the crank pulley bolt. Make sure it goes through a full revolution. Should do that anyways. This way if something is wrong you'll feel it and not have the starter still trying to crank after it hits something. Link to comment Share on other sites More sharing options...
Fire Away Posted December 18, 2013 Author Share Posted December 18, 2013 That is my other plan. I just went and looked again and while there isn't a notch on the crank pulley I can see or feel, the red mark on the pulley lines up with the notch on the CPS housing and the arrow on the pulley is pointed at 3 o clock, where it should be. So, while I don't know exactly how the cam turned It shouldn't be far off. That being said, the rest of the process went relatively smooth. Crank bolt came right out, crank pulley wasn't too much of a bear either. However, I am covered in PS fluid from the leaky pump. Just a few rusty bolts on the cam covers and the radiator fans. Link to comment Share on other sites More sharing options...
Osei Posted December 18, 2013 Share Posted December 18, 2013 Seems like you have it figured out. Don't look for the notch on the crank pulley. Look for the hash mark on the crank sprocket. When it is lined up, the key way will be at 6 o'clock. See the sticky for FSM. O. Link to comment Share on other sites More sharing options...
Fire Away Posted December 18, 2013 Author Share Posted December 18, 2013 I had a slight problem with terminology. I was referring to the markings on the cam sprocket not the crank pulley. I went an looked, felt, and took pictures of the cam sprocket. There are no markings other than the orange dash and a small arrow. Nothing on any of the bump outs for the CPS as noted in the FSM. The orange dash lines up almost perfectly at 44 teeth from the orange mark on the passenger side cam pulley. Link to comment Share on other sites More sharing options...
johnegg Posted December 19, 2013 Share Posted December 19, 2013 when the crank is right, the key way is in the 6 o'clock position. and the small triangle, if there is one, is point at 3 oclock. on the cams, the arrow on the spoke is pointing at 1.5 o'clock. halfway between 12 and 3. http://legacygt.com/forums/data:image/jpeg;base64,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 Link to comment Share on other sites More sharing options...
spooln30 Posted December 19, 2013 Share Posted December 19, 2013 Remember if your going to spin the cam gear back off the crank alignment. Otherwise you'll hit the valves on the pistons. Your lucky yours is a SOHC cuz the DOHCs can be a PIA sometimes. Link to comment Share on other sites More sharing options...
johnegg Posted December 19, 2013 Share Posted December 19, 2013 when the crank is in the correct timing alignment position, ALL pistons are at mid-stroke, halfway between top and bottom. there is no way for the valves to hit the pistons. but if you incorrectly put #1 at TDC as all other car makers require, then you could cause damage by turning the cams. Link to comment Share on other sites More sharing options...
Fire Away Posted December 19, 2013 Author Share Posted December 19, 2013 the red mark on the crank sprocket is on top of a round marking that seems to be where the notch on the crank sprocket should be. So, everything is aligned just fine. Now, to get it all back together... Link to comment Share on other sites More sharing options...
johnegg Posted December 19, 2013 Share Posted December 19, 2013 not unless the slot for the key way is straight down. Link to comment Share on other sites More sharing options...
