fredrik94087 Posted December 11, 2013 Share Posted December 11, 2013 2013 Legacy 3.6R intake and exhaust dyno not tuned. Please note that since this posting, I have changed my intake to a "modified" AFE Takeda setup which makes a few more ponies. http://legacygt.com/forums/showpost.php?p=4787507&postcount=28 2.2whp and 5wtq. 5whp/5wtq at 5250 rpm by adding exhaust on top of an intake mod. http://legacygt.com/forums/showpost.php?p=4671757&postcount=5 2 1/2" single exhaust with mandrel bends after factory Y pipe. Why? Primaries after the cats are 1 3/4" each After the Y, it is 2 3/8" 2 3/8" into the resonator 2 1/8" out of the resonator (not a typo, I remeasured!) Since the Y is 2 3/8", it doesn't make sense to go 3". 2.5" is the closest. I didn't go with a dual exhaust because it is a single after the Y pipe and, for me, that was unnecessary. My co-worker says the dual looks better. To each his own Sorry I didn't have better news. My butt dyno told me there wasn't much gain if any, and it proved to be true. I'm looking into a tune through Dietsch Werks in San Jose. We shall see if their tuner does a 3.6R. We know he tunes Subarus. Edited March 11, 2014: Tuner for Dietsch Werks was a no go. Looking at e-tune through Delicious tuning. Cheers! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
GTEASER Posted December 11, 2013 Share Posted December 11, 2013 What kind of muffler did you put on her? And I find it curious that you didn't go with a large pipe which may have produced less low end torque, but probably would have afforded an increase in top end hp. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 11, 2013 Author Share Posted December 11, 2013 What kind of muffler did you put on her? And I find it curious that you didn't go with a large pipe which may have produced less low end torque, but probably would have afforded an increase in top end hp. I should have mentioned... both straight through 2.5 to 2.5 4x9 ovals 14" by magnaflow. I will update first post later. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 11, 2013 Author Share Posted December 11, 2013 underbody with J pipe "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 16, 2013 Author Share Posted December 16, 2013 The car was feeling better and I had to know if there were any gains. Top end did not change, but it looks like the ECU had a chance to learn the exhuat mod. The A/F ratio is back to where it was when I did the intake. Last time, when I dynoed with the exhaust, I didn't wait long enough and the car was reading rich. I believe it was overcompensating for the slightly better airflow. The gain is around the 3500 to 5000 rpm range. It looks like a ~5whp and ~7wtq gain in the mid-range. And, the A/F ratio has normalized. Around 5500 rpm, the A/F ratios were reading the same, and it makes sense that there was no gain after 5500 rpm. But, in the range where the A/F ratio increased back to normal, there was a slight improvement. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
tama24 Posted March 12, 2014 Share Posted March 12, 2014 Great work on your 3.6r, very curious to see the post-tune dynos Link to comment Share on other sites More sharing options...
fredrik94087 Posted March 12, 2014 Author Share Posted March 12, 2014 Great work on your 3.6r, very curious to see the post-tune dynos Thanks! Believe me...I am too. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
