zennoodle Posted December 7, 2013 Share Posted December 7, 2013 I have been PM'ing a couple people on here. I popped off the intercooler with the help of a couple threads. I was trying to look around my engine bay for this blue T connector but could not find it. I saw a bunch of electrical connectors and that's it. The temperature his -12 degrees here in Denver and one day on the way to work it just idled super rough and then threw a check engine light and all that. I attached a picture of the engine bay looking down after I removed the intercooler. Any help is appreciated! Link to comment Share on other sites More sharing options...
Xplosivo1 Posted December 8, 2013 Share Posted December 8, 2013 I have an 08 and did not have the blue-t. Follow the vacuum lines from the turbo and make sure the are all in and right. Then go from the other side and follow the lines from the BPV and do the same thing. There is a line that connects directly to a manifold nipple that was constantly slipping off. Hope that helps, it sucks working In the cold without a clear direction... Link to comment Share on other sites More sharing options...
zennoodle Posted December 8, 2013 Author Share Posted December 8, 2013 I just found out that the blue T connector does not exist on 07+ turbo mobiles. Which side is the manifold nipple? If you have pics that'd be great. If not, I will probably run downstairs one more time to look at my car. Thanks for the help! Link to comment Share on other sites More sharing options...
Xplosivo1 Posted December 8, 2013 Share Posted December 8, 2013 http://legacygt.com/forums/showthread.php/bypass-valve-vacuum-hose-routing-211544.html I used this thread pic. It's taken looking toward the front of the car. The blue hose to the left if the pic is the throttle body hose. The nipple is almost centered, maybe slightly toward the driver side. Link to comment Share on other sites More sharing options...
zennoodle Posted December 8, 2013 Author Share Posted December 8, 2013 Sweet! Thank you so much! I'm going to take a peek at the car and see if I can come up with something! Link to comment Share on other sites More sharing options...
