Enraged Posted December 3, 2013 Share Posted December 3, 2013 Just put on some cheap winter wheels that are supposed to be 17x7.5 +40, and it seems to be rubbing in the rear when I hit bumps. My 05 LGT is at stock height. Should I just get some thin spacers? I'd rather not have to do extended lugs or anything, so what is a safe size? 6mm or 12mm? The fronts seem to be fine, but would I need spacers all around, or can I use them just in the back? Any help would be appreciated. Pic of the back of the wheel: http://image.usedvictoria.com/photos/01/13/35486913_934.jpg Link to comment Share on other sites More sharing options...
Drift Motion Posted December 3, 2013 Share Posted December 3, 2013 what's the tire size? where is it rubbing? if it's hitting the top of the fender/quarter panel, spacer won't help max spacer size on stock studs should be 7mm, but some people run up to 10mm... you can put 1 spacer if you wish, but it's not required in sets, hence why spacers are sold in pairs. Link to comment Share on other sites More sharing options...
Enraged Posted December 3, 2013 Author Share Posted December 3, 2013 225/45/17 Michelin X-Ice tires, I'll check where it's rubbing after work. Link to comment Share on other sites More sharing options...
