monsterface Posted November 29, 2013 Share Posted November 29, 2013 Hi Guys, I'm looking for some advice as to what mod's I should be looking at for my stage 3 setup. I'm leaning towards a stock location TD06-20g type setup. But I'm open to suggestions. I don't have a specific target goal persay, I know I just want MOAR. Ideally i'd like to do this on the stock block. The vehicle in question is a 05 Outback XT, and it currently has the following mods installed: 3" downpipe mated to the oem catback exhaust Cobb SF intake Grimmspeed EBCS Grimmspeed Up-pipe w/ 44mm tial ewg dumping to atmosphere AVO TMIC Cobb AP DW65C fuel pump DW740 cc injectors I made 232awhp and ~260ft.lbs @ 3500' asl on a dyno dynamics dyno with this setup incase your wondering. Tuned by airboy Here is my little list I've come up with so far, feel free to chime with your thoughts/suggestions. Bypass valve of some sort. (GFB unit maybe??) EL headers Clutch?? (is it necessary?) AOS (grimmspeed one won't cut it as I live in sub-polar climate, i'm thinking Crawford perfomance's AOS) turbo blanket + heatshield Misc hoses (TB to TMIC hose, turbo inlet hose) -Matt Link to comment Share on other sites More sharing options...
idiot4hire Posted November 30, 2013 Share Posted November 30, 2013 A vf52 or equivalent is the perfect size turbo IMO. What's your suspension like Link to comment Share on other sites More sharing options...
Lgtmark Posted December 1, 2013 Share Posted December 1, 2013 Im not sure if you have done it yet but a few mods I did that I love are the driveline mounts. Sti motor and tranny mounts with kartboy trans crossmember bushings, whiteline rear diff outrigger bushings and whiteline rear diff mount in cradle bushings. Made a big difference putting power to the ground and it wasn't super expensive. Another good mount is the Pitch stop mount. There was an increase in noise but I personally love the sound. Can hear the gears wind up in the tranny, plus the diff mounts will prevent your diff from slopping around. Link to comment Share on other sites More sharing options...
