Wheel size / offset
I've been looking for a list of wheel size / offset range for my 98 LGT. I found this - http://forums.nasioc.com/forums/showthread.php?t=335263 - Does this apply to our BG5s / BD5s?
I found some 18x8 wheels wrapped in 225/40/18, and they look sweet, but the wheel offset is only 35. According to the above linked post, they won't work. I'm going to be very sad if this is true...Anyone with clarity?
You will have to stretch a tire for any sort of aggressive fit if you are lowered.
Ideal fitment on a 2nd gen is a 9" wide wheel with a 48mm offset. You cannot get any more aggressive than that without it poking real far or hitting the strut assembly. I ran a 205/40/17 and had next to no rubbing issues unless at full lock going over bumps - I was also extremely low.
Disclaimer: I also did this with coilovers and had about a credit card's width of space between the strut and the inner lip. Best method is to test fit potential wheel size/offset of someone else first to see what clearance is like.
Disclaimer.....When I got my new 17" wheels the tires on that they came with were 245/40/R17. The width of the tire (245 part) didn't clear the spring perch in the rear. I needed 5mm spaces and reduced the tire size to 235/40/R17 and it worked like magic. No rubbing and that wheel tire combo is like super glue to the road! Amazing upgrade from the old OEM snowflakes.
Silver, you ran a 205 on a 9" wheel? That's totally unsafe.
Ran it for thousands and thousands of miles (on MA roads!) with 0 ill effects. You want an aggressive wheel fitment/stance you don't have an option, you're not getting that fitment with full sized tires ;).
Looking back at these pictures I never should have gotten rid of this thing. My car was so clean :lol:
Here are some pictures for reference of how the setup sat:
http://imageshack.us/a/img202/6363/xy8c.jpg
http://imageshack.us/a/img34/2074/jwat.jpg
http://imageshack.us/a/img560/8105/z3ji.jpg
http://imageshack.us/a/img812/7092/vbn1.jpg
http://imageshack.us/a/img593/7954/1c0e.jpg
Thats some crazy poke, and I don't want to stretch. I prefer just tucked under for good suspension travel and tires that are as wide as the wheel or wider. Most grip on the road as possible.
That's one slick looking bg though man...
Sent from my VS980 4G using Tapatalk
They were Stance GR+Pro's. They would have gone a lot lower but the bottom of the assembly spins out the bottom of the sleeve when you lower it, and if I were any lower it would have contacted the axle boots up front.
The good news was the frame notched itself :lol:
http://img690.imageshack.us/img690/7334/zyca.jpg
