robmat Posted November 23, 2013 Share Posted November 23, 2013 I pulled the drivers side axle out and when I look into the hole where the axle installs into the transmission, I can see a small metal spring peaking out from behind the gasket. When I checked it, the spring popped out. It looks very much like a retaining spring. Is there an easy way or trick to reinstall it. Thanks Robmat Link to comment Share on other sites More sharing options...
apexi Posted November 24, 2013 Share Posted November 24, 2013 Since no one has replied yet, it sounds like you're referring to the axle seal spring. I don't know much about that part, but hopefully the links below might point you in the right direction. http://legacygt.com/forums/showthread.php/help-identify-part-119588.html http://legacygt.com/forums/showthread.php/need-help-tranaxle-oil-seals-201537.html http://legacygt.com/forums/showthread.php/circular-spring-axle-transmision-173287.html Link to comment Share on other sites More sharing options...
CNY_Dave Posted November 25, 2013 Share Posted November 25, 2013 Axle seal spring, or the stub axle retaining spring clip? Link to comment Share on other sites More sharing options...
robmat Posted November 25, 2013 Author Share Posted November 25, 2013 Axle spring seal was the culprit. Picked up new seals today. Thanks guys! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
