blackdiamond18 Posted November 23, 2013 Share Posted November 23, 2013 So, my cars ABS light is on, and I did the diagnoses for the car and it gave me: C0102, C0108, and C0111. I found the chart and this is what the codes mean: C0102: ABS wheel speed sensor malfunction(Broken wire, short) Rear ABS wheel speed sensor LH C0108: ABS wheel speed sensor malfunction(ABS wheel speed sensor abnormal signal) Abnormal signal of front ABS wheel speed sensor LH C0111: Motor/motor relay on failure So I get that the first two (c0102 and c0108) mean that the front and rear left side sensors are acting up. Does that mean I should just get them both replaced? And what exactly does the code for C0111 mean? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ehsnils Posted November 23, 2013 Share Posted November 23, 2013 I would start with investigating the C0111 code. Check all fuses and connectors. It may be that there is a power failure or a problem with the ABS unit itself, and that the C0102 and C0108 are secondary failures. Look at the vacation pix. Link to comment Share on other sites More sharing options...
blackdiamond18 Posted November 24, 2013 Author Share Posted November 24, 2013 Ok, yea, I'm not trying to spend money on new sensors, so I'll check that Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
