tDoug60 Posted November 20, 2013 Share Posted November 20, 2013 ive used the search bar and i found something that could be the reason{low brake fluid} but i cant find the topic again that being said, i own a 07 lgt and i recently had my oil change from jiffy lube. so over the weekend when i was driving my brake light came on after a couple mins it went off, it comes on very random sometimes it will flash once or mulitple times or will stay on for a couple mins. anyone please help out. Link to comment Share on other sites More sharing options...
rob-2 Posted November 20, 2013 Share Posted November 20, 2013 Top up brake fluid it's sloshing around and low. Link to comment Share on other sites More sharing options...
ehsnils Posted November 20, 2013 Share Posted November 20, 2013 Check the brake fluid container level. Brake fluid is not oil - and don't have Jiffy Lube to look at it. If you aren't sure check with someone that's specialized in brakes, even Autozone may be able to help you. Brake fluid DOT 4 or DOT 5.1, but not DOT 5.0. Link to comment Share on other sites More sharing options...
SCASEYS Posted November 20, 2013 Share Posted November 20, 2013 check fluid 1st could be time to change the pads too likely the fluid I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
tDoug60 Posted November 20, 2013 Author Share Posted November 20, 2013 I've changed my rotors pad and ss lines 5 months ago. Ill check the brake fluid level today and if that's not it I guess ill take it to the dealer. Sent from my SAMSUNG-SGH-I337 using Tapatalk 2 Link to comment Share on other sites More sharing options...
