liftedtoy97 Posted January 10, 2014 Author Share Posted January 10, 2014 Got the head pulled off and no valves were bent. Haven't pulled the passenger head, not sure I will. Probably slap the new head on and see what happens. When I hit the clutch and the engine died, it stopped directly mid stroke for all pistons…something has to be screwed, I'm not that lucky Link to comment Share on other sites More sharing options...
spooln30 Posted January 12, 2014 Share Posted January 12, 2014 I believe ericthecarguy made a video explaining this. I'm assuming you watched it. His videos are extremely helpful No just 16 years in the business you learn things like this. Another trick if you don't have a leak down tester is to use a old spark plug and weld a adaptor for an air line and fill the cylinder that way. I didn't even notice how old this was. I was just trying to help. Btw that Eric the car guy I think he had a video about how to tighten the bearings for the front diff and failed miserably. He's a idiot. Link to comment Share on other sites More sharing options...
