turbosubaru Posted November 13, 2013 Share Posted November 13, 2013 I just had an open source street tune today. The tuner installed a solenoid kit to control higher boost. The check engine light came on when we were finishing(the speed around while I hold the laptop part so he can make adjustments) and this was the code. The tuner wasnt able to clear it with a tune (before we took it too the street he had cleared all codes relating to having no cats). He said that I dont need to worry about it, unless I started to feel problems. My car is an automatic and it drives amazing right now. He tuned it as far as he could safely without needing to modify or get new injectors. What do you guys think. Anyone experienced something similar. Link to comment Share on other sites More sharing options...
ehsnils Posted November 13, 2013 Share Posted November 13, 2013 That is the transmission control unit general code. You need to pull the codes from the TCU to get the details, but my primary suspicion would be that it did detect a slip or something. The first action would be to do a fluid change on the gearbox, then clear the code. If the code comes back it's a trip to the dealer to get the real codes. Link to comment Share on other sites More sharing options...
turbosubaru Posted November 13, 2013 Author Share Posted November 13, 2013 Okay thanks, so I need to change out transmission fluid. Is it true Autozone does free scans? Link to comment Share on other sites More sharing options...
underpowerd Posted November 13, 2013 Share Posted November 13, 2013 the 700 is an ecu code, but it's tied to tcu code(s) -- you can pull up/clear the tcu codes with freeSSM + tactrix -- but do pay some attention to what the tcu is throwing out; it can range from silly to grave. Link to comment Share on other sites More sharing options...
turbosubaru Posted November 14, 2013 Author Share Posted November 14, 2013 The code dissappeared on its own today, I didn't even change the transmission fluid. Link to comment Share on other sites More sharing options...
ehsnils Posted November 14, 2013 Share Posted November 14, 2013 In that case I suspect that it was slipping, so change the fluid. Just changing fluid doesn't reset the code, but a bad fluid in the gearbox may make it more prone to slipping and therefore throw a code. After a few starts where the code condition hasn't appeared the system resets the code again. All this means that it's often a good idea to try to read the code as soon as you get it to get help to figure out if it's serious or not. Link to comment Share on other sites More sharing options...
turbosubaru Posted November 15, 2013 Author Share Posted November 15, 2013 Thanks, should I be using Subaru transmission fluid? Or something else. I haven't had my car very long this will be my first time changing the transmission fluid. Link to comment Share on other sites More sharing options...
ehsnils Posted November 16, 2013 Share Posted November 16, 2013 Check the transmission section to see, but I would say that any good ATF fluid would work as long as it conforms to the spec for the gearbox. Link to comment Share on other sites More sharing options...
