Redryan98 Posted November 12, 2013 Share Posted November 12, 2013 I purchase a set of the epic engineering springs from the group buy and was excited to install them last night. The install went smoothly, but for some reason the net result is that the car actually sits slightly higher than it did before. Now I know I should allow maybe a week or two for the springs to settle, but they'd have to settle like 1-2 inches to sit where I would expect them too based on pictures I've seen. Obviously its not going to settle that much. The only reason I can think of is my shock/strut choice. I'm running JDM RevA SpecB struts and until last night Rev A springs. Maybe I should have researched more, but I assumed the shock's dimensions would be the same as the US versions. Am I wrong? Any other ideas as to why it might be sitting so high? I've got three finger gap on driver side and three and a half gap on passenger side. Link to comment Share on other sites More sharing options...
m sprank Posted November 13, 2013 Share Posted November 13, 2013 Have you driven the car? If not, you need to. Dropping the car down on the ground off the jack/lift/etc is not enough to set the springs. Link to comment Share on other sites More sharing options...
Redryan98 Posted November 14, 2013 Author Share Posted November 14, 2013 I have for a few days, no change. Appears to be an issue with running the bilstein setup. They have thicker strut mounts which in my case offset the drop these springs would give. I've got nothing bad to say about the quality of the springs and appreciate the GB. I just didn't do my homework. Link to comment Share on other sites More sharing options...
m sprank Posted November 14, 2013 Share Posted November 14, 2013 Bilsteins use the "GroupeN" front top hats which are 3/8" thicker than OEM LGT. This lifts the front end of the car approx 3/8" and gives a "saggy butt" look. Link to comment Share on other sites More sharing options...
Redryan98 Posted November 15, 2013 Author Share Posted November 15, 2013 I appreciate the info! PM Sent Link to comment Share on other sites More sharing options...
