jp71ss Posted November 12, 2013 Share Posted November 12, 2013 I have a vacuum hose on the pass side of engine compartment that I do not know where it goes. Can someone point me in the right direction or possibly post a pic of the 97 GT vacuum diagram so I can follow it? Thanks Johnhttp://i216.photobucket.com/albums/cc305/jp71ss/photo_zps2ea6f871.jpg http://i216.photobucket.com/albums/cc305/jp71ss/photo1_zps1f6ac0fd.jpg Link to comment Share on other sites More sharing options...
jarrodbrown94 Posted November 12, 2013 Share Posted November 12, 2013 There should a senser under the pass side of the intake it should conect somewhere on it. Mine conects to T looking conector on the same line as the fillter on yr first pic Link to comment Share on other sites More sharing options...
jp71ss Posted November 12, 2013 Author Share Posted November 12, 2013 The filter already has a tee on it and connected just above the head. Link to comment Share on other sites More sharing options...
IrishLt Posted November 12, 2013 Share Posted November 12, 2013 Mine conects to T looking conector on the same line as the fillter on yr first pic Correct. That line should connect to a "T", but it will then split into the evap system stuff. One side to the purge solenoid and the other line to the canister. Check for the T at the back of the intake, it should be around where the filter is on the other vac line. Good luck. Link to comment Share on other sites More sharing options...
jp71ss Posted November 12, 2013 Author Share Posted November 12, 2013 Then where does the one with the filter connect? At the moment filter has the T in it and is connected to the "EGR looking" thing and the intake. Link to comment Share on other sites More sharing options...
IrishLt Posted November 12, 2013 Share Posted November 12, 2013 Should be one of these under your hood somewhere. But they have been known to disappear. Link to comment Share on other sites More sharing options...
jp71ss Posted November 12, 2013 Author Share Posted November 12, 2013 Thanks guys, mine has disappeared at some point in time. I hope I can find everything easily. Link to comment Share on other sites More sharing options...
johnegg Posted November 13, 2013 Share Posted November 13, 2013 what are the circumstances, engine swap? head gaskets? use the diagram posted above and find all of the components. then look for an open nipple. unless you swapped in a different engine, it is there somewhere on the intake or under it. and it can't be too far since it is only so long. Link to comment Share on other sites More sharing options...
jp71ss Posted November 14, 2013 Author Share Posted November 14, 2013 I found behind the wiring harness. Thanks Link to comment Share on other sites More sharing options...
