jjanczak Posted November 11, 2013 Share Posted November 11, 2013 I have a 05 stage 2 lgt with a front mount intercooler. all of the connections in the front mount are tight and leak free but the coupling that goes from the last intercooler piping to the inlet on the manifold always seems to come off under higher boost. its the connection from that coupling to the manifold. im running 18psi. is there a heavier duty coupling I could buy? I have the hose clamp on really tight. any input I would appreciate. thanks. Link to comment Share on other sites More sharing options...
idiot4hire Posted November 11, 2013 Share Posted November 11, 2013 What kind of clamp are you using. Cheap Worm clamps can come loose sometimes. Link to comment Share on other sites More sharing options...
jjanczak Posted November 11, 2013 Author Share Posted November 11, 2013 that's the type of clamp I am using. I could try a more expensive clamp. Link to comment Share on other sites More sharing options...
idiot4hire Posted November 11, 2013 Share Posted November 11, 2013 It's an idea I've never had this problem but I have over tightened a worm clamp and ruined it pretty easy. Link to comment Share on other sites More sharing options...
GTTuner Posted November 11, 2013 Share Posted November 11, 2013 T bolt clamp Link to comment Share on other sites More sharing options...
jjanczak Posted November 11, 2013 Author Share Posted November 11, 2013 I will give that a shot. thanks guys! Link to comment Share on other sites More sharing options...
Brian3676 Posted November 11, 2013 Share Posted November 11, 2013 Any coupling on a intercooler system should really be t bolt clamp. Link to comment Share on other sites More sharing options...
