collier89139 Posted November 10, 2013 Share Posted November 10, 2013 1996 subaru legacy Changed water pump,thermostat, timing belt Still over heats Anyone have any thoughts? Link to comment Share on other sites More sharing options...
Scruffy Posted November 10, 2013 Share Posted November 10, 2013 Test that one thing that you're dreading it may be. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 10, 2013 Share Posted November 10, 2013 We've been answering those, and more questions for days now. This thread covers most ever possibility. http://legacygt.com/forums/showthread.php/overheating-2-5-am-loss-ideasi-216390.html Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 10, 2013 Share Posted November 10, 2013 Air bubbles, bad head gaskets, aftermarket tstat... Link to comment Share on other sites More sharing options...
collier89139 Posted November 12, 2013 Author Share Posted November 12, 2013 so I have replaced the radiator and it is still overheating it seems that the passenger side is much hotter than the driver side I am also getting some gurgling sound anyone have any thought Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 12, 2013 Share Posted November 12, 2013 What brand thermostat are you using? Non OEM ones have been known to cause issues. Have you purged all of the air out of the system? Link to comment Share on other sites More sharing options...
99subigt Posted November 12, 2013 Share Posted November 12, 2013 1996 subaru legacy Changed water pump,thermostat, timing belt Still over heats Anyone have any thoughts?. When my legacy overheated I changed the exact same parts and it overheated a second time, second time was worst cause it was in the rain and I did not realized that it was running super hot. So my bro machined the cylinders and changed the head gasket and problem solved Link to comment Share on other sites More sharing options...
99subigt Posted November 12, 2013 Share Posted November 12, 2013 Like the others say it depends on the brand of the thermostat too, I got one but it was not working right and it could be the radiator too and make sure all hoses are tight Link to comment Share on other sites More sharing options...
suprastarr Posted November 13, 2013 Share Posted November 13, 2013 I don't want to jack the thread but.... what kind of issues will a non-Subaru thermostat cause? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 13, 2013 Share Posted November 13, 2013 Overheating because it does not open correctly. Either it doesn't open enough or it does not open at the correct temperature. No one can say for sure, but we've seen issues go away when a crap aftermarket thermostat has been replaced. Link to comment Share on other sites More sharing options...
