swagon2.5 Posted November 5, 2013 Share Posted November 5, 2013 I have a 98 Legacy GT with the original 4EAT and I'm having problems with the shifter. When you move the shifter to select 'Drive' the transmission stays in neutral. You have to go into 3rd and then move the shifter so it is half way between 3rd and drive to actually be in 'Drive' I've adjusted the cable as to All-Data and Mitchell's procedure yet the car still has the issue. I'm ready to get a new cable and try that. Any tips or ideas? Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 5, 2013 Share Posted November 5, 2013 Did you check the inhibitor switch on the passenger side of the trans? It has to be in the right position for it to work right. It is held on by four screws and the screw holes are slotted so it can be adjusted. Link to comment Share on other sites More sharing options...
swagon2.5 Posted November 5, 2013 Author Share Posted November 5, 2013 I did check that too. The 1/8 pin slides in with no snags at all Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 5, 2013 Share Posted November 5, 2013 Did you try adjusting the inhibitor switch? When I replaced mine I had it out of adjustment and to get it in drive I had to fuss with it too. Link to comment Share on other sites More sharing options...
swagon2.5 Posted November 6, 2013 Author Share Posted November 6, 2013 hmm I will check that Link to comment Share on other sites More sharing options...
