Gabriele85 Posted November 4, 2013 Share Posted November 4, 2013 Hi all, since i bought my legacy i had some trouble with the rear left door. when i lock the doors by the key the rear left doesen`t function as well As Like normally it should be.. So..i want to fix it but i'd prefer to have some advices before i start.. Is there Any particular stuff i should know!? PS: I know my english sucks so i'll be very gratefull if someone can pm me a correct way to write it... :icon_chee:icon_chee Link to comment Share on other sites More sharing options...
dga Posted November 4, 2013 Share Posted November 4, 2013 Your English is good enough to understand. What is the exact issue you are having? The door does not lock/unlock as well as the other ones? Honestly...not sure where to start till you take her apart. Hopefully you can get the door open so that you don't have to bust the inside plastics trying to get to it. There is a full factory service manual floating around here somewhere. It's for US cars, but I can't see the Italian market ones being much different. Link to comment Share on other sites More sharing options...
Gabriele85 Posted November 5, 2013 Author Share Posted November 5, 2013 The door open and close as well as the others, but when i have to lock the car and i press the key button the door doesn't lock ..the only way to be sure to do it is using the "lock/unlock switch" on the door...hope you can understand me.. even if some times when i press more than one time the key the door lock correctly. Link to comment Share on other sites More sharing options...
