collier89139 Posted November 4, 2013 Share Posted November 4, 2013 I am changing out the water pump on my 1996 Subaru legacy I want to know if anyone has any tips or tricks on removing the center pulley bolt Thank you Link to comment Share on other sites More sharing options...
Kevlar_07 Posted November 4, 2013 Share Posted November 4, 2013 I always use a 3/8 impact gun, you could use a long ratchet and a hammer to get the same shock effect to the bolt Link to comment Share on other sites More sharing options...
mailman Posted November 4, 2013 Share Posted November 4, 2013 You can put a breaker bar against the frame or the ground, disconnect the ignition coils, and bump the key. there are also holes between the engine and transmission that you can get to (from under the hood) and stick a screwdriver in- that's the best way to torque it back too. Make sure you use a strong enough screwdriver though. The holes are very small and hard to find the first time. Link to comment Share on other sites More sharing options...
Ivant Posted November 4, 2013 Share Posted November 4, 2013 You can put a breaker bar against the frame or the ground, disconnect the ignition coils, and bump the key. there are also holes between the engine and transmission that you can get to (from under the hood) and stick a screwdriver in- that's the best way to torque it back too. Make sure you use a strong enough screwdriver though. The holes are very small and hard to find the first time. That's interesting. You wouldn't be able to narrow down where those holes are would you. I would imagine that a lot of time could be wasted looking for them, or even if you found the right ones. Are they on top, on the side or even under the car ? Link to comment Share on other sites More sharing options...
snederhiser Posted November 5, 2013 Share Posted November 5, 2013 Hello; It's been awhile since I have done this, the crank bolt is left handed (I believe). I took a longer bolt and ground a 30 degree cone on the end. If you look on the right hand side of the engine bellhousing there is a threaded thru hole. I thread in the bolt until it hits the flywheel starter teeth and rock the shaft to be sure the cone engages the teeth and tighten. If you have a automatic, just pull the upper housing cover and use a prybar to lock the flywheel. Hope this helps, Steven. Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 5, 2013 Share Posted November 5, 2013 I posted pics of the access hole here (scroll down): http://legacygt.com/forums/showthread.php/loose-crank-pulley-stripped-asap-190541p2.html Link to comment Share on other sites More sharing options...
twisty Posted November 5, 2013 Share Posted November 5, 2013 i did mine before i saw monkeys good pics for it, i used a chain plier with a piece of timing belt on the pulley to get it loose. had a friend hold the pliers and i used a 24" breaker bar with a 2ft piece of conduit as an extension. worked like a charm. Link to comment Share on other sites More sharing options...
johnegg Posted November 5, 2013 Share Posted November 5, 2013 found it. this works great for the auto trans. not quite as well for the manual trans. http://legacygt.com/forums/showthread.php/ap-pulley-install-173227.html?t=173227&highlight=screwdriver+flexplate http://i226.photobucket.com/albums/dd191/boostedbug/Subaru%20conversion/valance019.jpg Link to comment Share on other sites More sharing options...
Ivant Posted November 9, 2013 Share Posted November 9, 2013 What a great piece of advise. I wish I knew about those holes years ago. When I think about all the maori ways that I have used to tighten that bolt over the years and all the time there has been a hole there that I only needed to stick a screwdriver in. If only I'd known. The first thing I did after reading this was to go and check it out, and sure enough there it was only two seconds to stick the screwdriver in and it was held securely so the bolt could be tightened. I can't believe it, a manufacturer making a car with maintenance in mind, there's a first. Link to comment Share on other sites More sharing options...
