KeithMock Posted October 9, 2013 Share Posted October 9, 2013 Going to do the timing belt on my 06 Outback. Been digging around on the posts here and it looks pretty straight forward. My only question/concern is how do I know the crank pulley is correctly indexed when I reinstall? I don't see a keyway in any of the photos on the posts which I am used to. Link to comment Share on other sites More sharing options...
lockmedic Posted October 9, 2013 Share Posted October 9, 2013 The pulley and crank are keyed. . just a standard woodruff key. Not that it matters, Subarus are internally balanced so you could hypothetically put it on in any clock position and it would be fine. The key is just there to keep the crank pulley and timing belt pulley from spinning on the crank nose. You'll see it when you get it apart. Link to comment Share on other sites More sharing options...
KeithMock Posted October 9, 2013 Author Share Posted October 9, 2013 Thanks. Wanted to see if anyone knew BEFORE I pulled it apart and got myself in deep water! Also, as long as I didn't need to time it, it could go on in any location. Link to comment Share on other sites More sharing options...
lockmedic Posted October 9, 2013 Share Posted October 9, 2013 Just to be perfectly clear, it'll only go on one way. . .it just doesn't have to. You'll see the key in the crank and the groove in the pulley once you get it off. Just eyeball it and rotate it back and forth a little bit as you slide the pulley back on the crank and you'll feel it engage. Link to comment Share on other sites More sharing options...
KeithMock Posted October 9, 2013 Author Share Posted October 9, 2013 I have done pulleys before with keys so, no problem. Thanks again. Link to comment Share on other sites More sharing options...
