mmanus88 Posted August 18, 2005 Share Posted August 18, 2005 i am currently faced with making a decision on my car which is still in shop from car crash. the shop guy mentioned just keeping 18s and going with larger profile tires (since i did not like driving in NJ with low profiles). my 18s already had low profile toyo proxes 4 tires, so i wondered if this possible to do on the stock system without modification? if so what size tire would i be using? Link to comment Share on other sites More sharing options...
mmanus88 Posted August 18, 2005 Author Share Posted August 18, 2005 ? Link to comment Share on other sites More sharing options...
SC GT Posted August 18, 2005 Share Posted August 18, 2005 Bigger than what? Don't know how wide your rims are, their offset, or the size of your current tires, so can't answer your question. Link to comment Share on other sites More sharing options...
mmanus88 Posted August 18, 2005 Author Share Posted August 18, 2005 225/40/18 i beleive, 80% sure would going bigger with stock car be feasible? or is just getting 17 inchers with proper tire size more practical? Link to comment Share on other sites More sharing options...
SC GT Posted August 18, 2005 Share Posted August 18, 2005 I suppose you could try 225/45/18. Would screw with the accuracy of your odo/speedometer because it's such a tall tire, but I would think they will fit as long as you aren't lowered. Xenonk would know. Someone on the board is selling some 225/45/18s pretty cheap. Link to comment Share on other sites More sharing options...
Xenonk Posted August 18, 2005 Share Posted August 18, 2005 ^ correct. You can fit a 25.5" tire at best, say good bye to your speedo and odometer readings. (Stock is 24.8" diameter tire) Keefe Keefe Link to comment Share on other sites More sharing options...
red beast Posted August 18, 2005 Share Posted August 18, 2005 ^ correct. You can fit a 25.5" tire at best, say good bye to your speedo and odometer readings. (Stock is 24.8" diameter tire) Keefe thats all? mines 27.2" dia on the outback 3.0r Link to comment Share on other sites More sharing options...
Xenonk Posted August 18, 2005 Share Posted August 18, 2005 that's an OBXT/3.0R... bigger tires and taller suspension. GTs and I's run 25" stock. Keefe Keefe Link to comment Share on other sites More sharing options...
eVoMotion Posted August 20, 2005 Share Posted August 20, 2005 Ok - I am confused. My OBXT had RE92A 22/55/17 = 26.2. What size tires does your 3R have red beast? Link to comment Share on other sites More sharing options...
