iggybdawg Posted September 30, 2013 Share Posted September 30, 2013 Has anyone tried these on a Legacy or Impreza? http://www.ground-control-store.com/products/description.php/II=926/CA=97 I'm thinking they won't fit because of the pinch weld behind the strut tower being so close. Link to comment Share on other sites More sharing options...
iggybdawg Posted September 30, 2013 Author Share Posted September 30, 2013 Hmm, here's a better option http://www.hancheyvehicletech.com/mm5/merchant.mvc?Screen=PROD&Store_Code=HVT&Product_Code=810TM-FT86 I am on the hunt for non-raising camber plates. Link to comment Share on other sites More sharing options...
iggybdawg Posted September 30, 2013 Author Share Posted September 30, 2013 Hmm, BRZ forums seem to indicate their strut tower matches GC (-07 Impreza), whereas 05+ Legacy seems to match GR (08+ Impreza) Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 30, 2013 Share Posted September 30, 2013 Hmm, BRZ forums seem to indicate their strut tower matches GC (-07 Impreza), whereas 05+ Legacy seems to match GR (08+ Impreza) I've read that too about the Impreza. Good luck getting a response from GC. I contacted them awhile ago with measurements to see if one of their existing coilover conversion kits would would fit the LGT. I would try Vorshlag. I looked into getting stock spring camber plates from them for my M3 when the whole camber debacle was going on. They said it could be done. I'm sure they already have the necessary info on the LGT since they sell ASTs for it. Link to comment Share on other sites More sharing options...
iggybdawg Posted September 30, 2013 Author Share Posted September 30, 2013 I have GTWorx camber plates right now that look like the pics of Vorschlags in a different color, but they jack up the car like an outback. Link to comment Share on other sites More sharing options...
whitetiger Posted October 3, 2013 Share Posted October 3, 2013 the whiteline top hats could be what you want, though they arent adjustable, then do give more camber and then you can fine tune with camber bolts. you can also use them to get more caster too. Link to comment Share on other sites More sharing options...
iggybdawg Posted October 3, 2013 Author Share Posted October 3, 2013 I read on another thread that the Whiteline tophats didn't go well with bilsteins? Although, that person had put them on Bilstein HD's and I'm using bilstein pss's Would they have different screws at the top? On Monday, I emailed Racecomp Engineering, as they have GC Impreza lowering plates that look like cups. I asked if they are planning GR Impreza lowering plates. They replied yes. Link to comment Share on other sites More sharing options...
iggybdawg Posted February 5, 2014 Author Share Posted February 5, 2014 Racecomp Engineering to the rescue http://www.racecompengineering.com/index.php/subaru/05-09-legacy-gt/suspension/racecomp-engineering-camber-plates-for-08-sti-lowering.html Link to comment Share on other sites More sharing options...
