zildjiank Posted August 18, 2005 Share Posted August 18, 2005 I called the tire rack and they told me that the GT2's don't fit the legacy, because the way they look them up, by car and not by specs, he couldn't tell me whether it fit or not, or even what bolt pattern it came in, or the offset. Does anyone have this wheel on the LGT? Who did you get it from? And what are the specs? I want to see the 18X8.5... Link to comment Share on other sites More sharing options...
Xenonk Posted August 18, 2005 Share Posted August 18, 2005 18x8 works with the +51 offset... 18x8.5 +48mm is a tough fitment, but it's doable.. 245/35/18 would be the max tire. http://www.racecompengineering.com had a set that I barrowed for a test fitment and they cleared just fine even on a lowered car with coilovers. You may need to roll the rear fenders and you would DEFINITELY need to take off the rubber weather stripping off the rear fender for it to clear. Expect some rubbing from the bumpsteer when you turn the wheel to the lock. Keefe Keefe Link to comment Share on other sites More sharing options...
drewster Posted August 18, 2005 Share Posted August 18, 2005 guess it's too much work to do a search, huh? me, 18x8.5 et48 but on an outback here, 18x8 et51 on a legacygt http://legacygt.com/forums/showthread.php?t=14395&highlight=ssr+gt2 crazy thing is i will be in sacramento today... Link to comment Share on other sites More sharing options...
zildjiank Posted August 18, 2005 Author Share Posted August 18, 2005 Gonna be in sac town eh? Well, then maybe you and I can rule this town for today! Cause I rule it everyday...there ain't nobody w/ this car around town, i've only seen one GT in 6 months of flaunting around sacramento.... Link to comment Share on other sites More sharing options...
icelatte Posted August 18, 2005 Share Posted August 18, 2005 Just got mine in 18x8 with 225/40/18 No problems with fitment. I called Luke to get mine. He's on vacation right now but just pretend you're buying them for a wrx. Their computer won't let them order it for a legacy. I think you emailed me and I accidently deleted it, sorry. I'll post pics tonight. Link to comment Share on other sites More sharing options...
miles Posted August 18, 2005 Share Posted August 18, 2005 You guys buying SSR rims, are you buying 1 or 2 extra rims, since SSR has gone under (bankrupt)? Link to comment Share on other sites More sharing options...
zildjiank Posted August 18, 2005 Author Share Posted August 18, 2005 They did huh? Is that why the rims are so expensive? What happened w/ that? When did it happen? Link to comment Share on other sites More sharing options...
zildjiank Posted August 18, 2005 Author Share Posted August 18, 2005 18x8 works with the +51 offset... 18x8.5 +48mm is a tough fitment, but it's doable.. 245/35/18 would be the max tire. www.racecompengineering.com had a set that I barrowed for a test fitment and they cleared just fine even on a lowered car with coilovers. You may need to roll the rear fenders and you would DEFINITELY need to take off the rubber weather stripping off the rear fender for it to clear. Expect some rubbing from the bumpsteer when you turn the wheel to the lock. Keefe I thought you said that a 48mm offset would do fine for an 18X8.5 rim...or is that just because this one wheel's fitment in that size is wierd for our car? So, if 48mm offset barely works, then what is the preferred offset for 8.5" rim? Link to comment Share on other sites More sharing options...
Xenonk Posted August 18, 2005 Share Posted August 18, 2005 go higher with a +51 I think Tanabe bought up SSR now since SSR had issues with financial difficulty from making soo many rims and had issues keeping their books straight. Dont worry, SSR will continue on. Keefe Keefe Link to comment Share on other sites More sharing options...
icelatte Posted August 18, 2005 Share Posted August 18, 2005 Here they are. I thought about going 18x8.5 , they're $40 cheaper than the 18x8 but I don't think I'll ever go 255. If they get any cheaper I think I will buy a spare. Link to comment Share on other sites More sharing options...
miles Posted August 19, 2005 Share Posted August 19, 2005 I think Tanabe bought up SSR now since SSR had issues with financial difficulty from making soo many rims and had issues keeping their books straight. Dont worry, SSR will continue on. Keefe Thanks Keefe! Link to comment Share on other sites More sharing options...
zildjiank Posted August 20, 2005 Author Share Posted August 20, 2005 Shoot, 255 is what i'm shootin for, but just can't seem to find the right wheel for...and Keefe just said that the 18X8.5 wheel 48mm offset will have fitment issues... So, where do I go to get my fenders rolled? Anyone else done it? keefe, you done it? Link to comment Share on other sites More sharing options...
Xenonk Posted August 20, 2005 Share Posted August 20, 2005 I am about to get my fenders (rear only) rolled soon for the fitment of some r-compounds (Advan A032s) 245/40/17 with a set of 17x8" +40mm offset rims... http://www.tireswap.com does rent out a fender roller.. just email them for details. Keefe Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted August 20, 2005 Share Posted August 20, 2005 Shoot, 255 is what i'm shootin for, but just can't seem to find the right wheel for...and Keefe just said that the 18X8.5 wheel 48mm offset will have fitment issues... So, where do I go to get my fenders rolled? Anyone else done it? keefe, you done it? a 8.5" +48 is very close... especially with a 255.. a 245 wouldnt be as much of a problem.. the concern is that every tire is made differently, even if it's compared at the same size. That is the chance you take when you are maxing out that much of the fender well for a rim and tire without some kind of modifications. Keefe Keefe Link to comment Share on other sites More sharing options...
zildjiank Posted August 21, 2005 Author Share Posted August 21, 2005 a 8.5" +48 is very close... especially with a 255.. a 245 wouldnt be as much of a problem.. the concern is that every tire is made differently, even if it's compared at the same size. That is the chance you take when you are maxing out that much of the fender well for a rim and tire without some kind of modifications. Keefe Ok, so let's say I shot for a 245/35/18 Falken Azensis....or however you spell that...I hear they are wide, and that tire just might be as wide as some others in 255 measurements... Will that tire fit with the same rim fitment? or is the rim the problem, and not the tire? Link to comment Share on other sites More sharing options...
Xenonk Posted August 21, 2005 Share Posted August 21, 2005 do they even make a 245/35/18 Azenis?? (no).. you can get a 235/40/18 and run a 18x8 +51 offset as the widest you can go without rubbing. If you are sticking with the 18x8, just get the 225/40/18 and it will be just fine because it's built like a 235 anyways.. the 235/40/18 might be built closer to a 245 or even a 255 possibly. Not sure if you are saying or asking if it's a rim or tire fitment problem. The rim is what dictates everything (tells you where the tire is located in the fender as well as telling you how wide a tire is allowed on the wheel). http://www.1010tires.com Keefe Keefe Link to comment Share on other sites More sharing options...
MUD Posted August 22, 2005 Share Posted August 22, 2005 Would the same offset work (40mm) work when stepping from 18" to 19" wheel if the widths are the same @ 8"? It is the disposition of men to desire that which he cannot have, hence my un-quenchable wet desire for Shakira! Link to comment Share on other sites More sharing options...
