urdrwho Posted September 20, 2013 Share Posted September 20, 2013 The car runs well at highway speeds, no notice of any burps and has a lot of pep. Last night I made a 90 mile round trip, most was on the highway doing about 45 MPH. There was a 10 minute stop and go traffic jam. On the trip my MPG was @26 and that is very acceptable for a 97 Outback AWD. Around town in my stop and go the MPG varies from a low 15 to around 17. It all makes me wonder about the intermittent P304. I never, ever, not once in 5,500 miles set a P304 while cruising on the highway. The code is always 100% of the time set either while waiting at a stop light or as I take off from the stop light. If the misfire is a mechanical problem wouldn't the code appear on the highway, off the highway, sitting, etc? Link to comment Share on other sites More sharing options...
johnegg Posted September 20, 2013 Share Posted September 20, 2013 wires first. then maybe plugs. or if you have the time, move the #4 wire to the front, either #1 or #2. see if the misfire moves as well. car???????????????? Link to comment Share on other sites More sharing options...
urdrwho Posted September 21, 2013 Author Share Posted September 21, 2013 New wires New plugs New coil I can move the #4 wire to the #2 coil hole? 97 outback limited with 2.5 wires first. then maybe plugs. or if you have the time, move the #4 wire to the front, either #1 or #2. see if the misfire moves as well. car???????????????? Link to comment Share on other sites More sharing options...
johnegg Posted September 22, 2013 Share Posted September 22, 2013 if, big IF, you have checked everything else, do a compression tests on #4. if the valves are not, were not, adjusted at 105k, you could have a burned exhaust valve. for dome reason i do not know, #4 is the first to go. you can do the compression test any time. but i would not ASSUME a burnt valve until you have checked all the rest. Link to comment Share on other sites More sharing options...
urdrwho Posted September 23, 2013 Author Share Posted September 23, 2013 John, to check the timing can the side covers be removed without removing a lot of other bits? If so, I guess that I can then get a socket on the crank nut without removing the fans. if, big IF, you have checked everything else, do a compression tests on #4. if the valves are not, were not, adjusted at 105k, you could have a burned exhaust valve. for dome reason i do not know, #4 is the first to go. you can do the compression test any time. but i would not ASSUME a burnt valve until you have checked all the rest. Link to comment Share on other sites More sharing options...
