dobbs Posted September 17, 2013 Share Posted September 17, 2013 Ok guys and gals, Ive been trying to figure this one out for quite some time. So i get this rattle (as heard in the video) it happens between 1000-2000 rpms but really only on the down fall. It happens once its been running for a few min but not when its cold. It happens while driving, parked, in gear or neutral. If i rev it up above 3-4k it will NOT do it on the down fall between the 1-2k range. It did become more noticeable once i put the intake on it. I do have a couple ideas what it may be. Im thinking maybe the cat is broke or the Waste-gate actuator. Now i started the video just after i started the car, the car was a little warm. As you can hear i try and duplicate the noise, After a min or two you can start to hear the rattle. I started the video on the passenger rear of the car and once the rattle started you can see where i brought the camera around to the drivers side, then i brought it back around to the passenger side down by the turbo at the end of the video. Any suggestions would be greatly appreciated! Link to comment Share on other sites More sharing options...
dobbs Posted September 18, 2013 Author Share Posted September 18, 2013 morning bump.. anybody? Link to comment Share on other sites More sharing options...
JermTheElf Posted September 18, 2013 Share Posted September 18, 2013 Do you still have a cat in the up pipe? Link to comment Share on other sites More sharing options...
dobbs Posted September 18, 2013 Author Share Posted September 18, 2013 I do. everything is factory in the exhaust system Link to comment Share on other sites More sharing options...
JermTheElf Posted September 18, 2013 Share Posted September 18, 2013 Could be your cat up pipe breaking apart Link to comment Share on other sites More sharing options...
dobbs Posted September 18, 2013 Author Share Posted September 18, 2013 Ok im going take it off today ill let yall know what I find Sent from my SPH-L720 using Tapatalk 2 Link to comment Share on other sites More sharing options...
dobbs Posted September 19, 2013 Author Share Posted September 19, 2013 So today I decided to take off the down pipe to check the turbo. .. Sent from my SPH-L720 using Tapatalk 2 Link to comment Share on other sites More sharing options...
lingling1337 Posted September 19, 2013 Share Posted September 19, 2013 Too much play? Link to comment Share on other sites More sharing options...
dobbs Posted September 19, 2013 Author Share Posted September 19, 2013 Im not sure not too familiar to how a turbo is supposed to feel Sent from my SPH-L720 using Tapatalk 2 Link to comment Share on other sites More sharing options...
EJ25subie05 Posted September 19, 2013 Share Posted September 19, 2013 that is starting to show some age but as long as you dont have any in and out play then youll be fine for a while. But make sure to get rid of that cat in the uppipe first before you do anything else. Link to comment Share on other sites More sharing options...
SBT Posted September 19, 2013 Share Posted September 19, 2013 What DP are you running? And is it a divorced WG type? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
dobbs Posted September 19, 2013 Author Share Posted September 19, 2013 Everything is factory on the car except the intake. Sent from my SPH-L720 using Tapatalk 2 Link to comment Share on other sites More sharing options...
SBT Posted September 19, 2013 Share Posted September 19, 2013 It's clearly metal-on-metal, seems to be internal to the exhaust itself - possibly the UP catalyst decomposing and bits rattling in the turbine. Otherwise, it appears to be associated with the WG activity. I would imagine that this is also affecting your knock sensor given its proximity to the turbo. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Cobshane Posted September 19, 2013 Share Posted September 19, 2013 The play is normal, even brand new turbos have play. As said if the play is in and out that's bad news. Possible you have a loose heat sheild on the exhaust too. Link to comment Share on other sites More sharing options...
