phesa1005 Posted August 30, 2013 Share Posted August 30, 2013 i'm planning to upgrade to a bigger turbo/intercooler. i'm currently stock but want just a lil more power. i'm getting up pipe,down pipe,access port soon too Link to comment Share on other sites More sharing options...
blongo804 Posted August 30, 2013 Share Posted August 30, 2013 For street application? BNR 16g or OEM '09+ WRX VF52. For the money, cannot beat either of these options. Intercooler-wise, either get the bulletproof kit assuming your stock IC is ok still or wait for Grimmspeed to release theirs. If you can't wait, go with a used AVO one since they pop up often. Good luck!! Link to comment Share on other sites More sharing options...
grovlet Posted August 30, 2013 Share Posted August 30, 2013 For street application? BNR 16g or OEM '09+ WRX VF52. For the money, cannot beat either of these options. Intercooler-wise, either get the bulletproof kit assuming your stock IC is ok still or wait for Grimmspeed to release theirs. If you can't wait, go with a used AVO one since they pop up often. Good luck!! Is GrimSpeed making an LGT fitment I/C? As far as I saw it was STI Fitment only? I guess if you're upgrading the Turbo too it's not a huge deal, but I hadn't heard anything about direct fit replacements..... Link to comment Share on other sites More sharing options...
grovlet Posted August 30, 2013 Share Posted August 30, 2013 i'm planning to upgrade to a bigger turbo/intercooler. i'm currently stock but want just a lil more power. i'm getting up pipe,down pipe,access port soon too SubiMods is also working to get the Process West LGT Fitment Kit back to the USA:wub: And FYI - with a bigger Turbo it would be a good idea to plan for upgraded injectors and fuel pump, and Electronic Boost Controler. Depending on Turbo Choice they may not be required, but you'll need a tune anyways and they can make it that much safer and easier... And as a side note - just stage 2 compared to stock is a nice improvement... So if your just looking for an upgraded DD - you may only need Up/Down Pipe and tune to make you smile:cool: Link to comment Share on other sites More sharing options...
lee07 Posted August 30, 2013 Share Posted August 30, 2013 Get those parts installed and tuned and see how you like it first. It might be more than enough for you. If it's not, vf52 or 16g Link to comment Share on other sites More sharing options...
