Redryan98 Posted August 29, 2013 Share Posted August 29, 2013 Hi All. I recently picked up an 07 Legacy GT with just under 50k miles. Its extremely clean and runs well. I love it. That said as with any used car it needs a little bit of work. First up is the driver seat. I'm not sure how, but its falling apart. There's a medal wire sticking out of the leather on the left side of the seat, and the right side bottom cushion frame has almost completely failed, sagging to the right with an awful lot of creaking as well. So, I need a new seat. I've found like what looks like a good option, however its out of an 09 Legacy. I believe the design of the 07-09 seats were the same. Can anyone confirm this will be a plug and play swap? Mucho gracias! Link to comment Share on other sites More sharing options...
mondo Posted August 29, 2013 Share Posted August 29, 2013 If your original seats had airbags, as the 09, you could be ok, otherwise you could have an issue with the airbag lamp staying on. Link to comment Share on other sites More sharing options...
Redryan98 Posted August 29, 2013 Author Share Posted August 29, 2013 ^Thanks! I believe the 07 did have seat airbag so I should hopefully be good but I'll double check. Anyone else have any experience with this? Link to comment Share on other sites More sharing options...
