V-Power Posted August 16, 2005 Share Posted August 16, 2005 Having difficulties shifting in Reverse after starting car (5 speed manual). Coming from Honda Accord 5mt, the trick was shift in second then reverse with no problem. Now I shift in 1st with the LGT, move the car forward a few inches and I can find reverse. Any ideas what this is all about? Link to comment Share on other sites More sharing options...
GeorgeB Posted August 16, 2005 Share Posted August 16, 2005 the reverese is not sinchronised with all the gears just with 1st that is all, u don't have to move the car, just put in 1st, lift the clutch until u sense the care moving, then u can put it in reverse with ease. Link to comment Share on other sites More sharing options...
TSiWRX Posted August 16, 2005 Share Posted August 16, 2005 Ayup, no Synchro for reverse. Either do the "first-to-reverse" trick, or double-clutch. Both work like a charm. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
RobY Posted August 16, 2005 Share Posted August 16, 2005 Just double clutch Link to comment Share on other sites More sharing options...
GeorgeB Posted August 16, 2005 Share Posted August 16, 2005 or do the 1st - reverse thingy Link to comment Share on other sites More sharing options...
gargleblaster Posted August 16, 2005 Share Posted August 16, 2005 Doppleclutchen Founder - The Harry F. Johnson Memorial Fund Link to comment Share on other sites More sharing options...
V-Power Posted August 16, 2005 Author Share Posted August 16, 2005 Thanks folks! Link to comment Share on other sites More sharing options...
kiem Posted August 16, 2005 Share Posted August 16, 2005 i dont have th 5mt.. but what is double clutch? Link to comment Share on other sites More sharing options...
scans007 Posted August 16, 2005 Share Posted August 16, 2005 You push the clutch in, (try to shit into gear if you want ....it doesn't work)....let out the clutch all the way, push clutch back in, and shift into reverse...... Double Clutch'n Link to comment Share on other sites More sharing options...
GeorgeB Posted August 16, 2005 Share Posted August 16, 2005 it's a maneuvre used on old trucks with no sync between gears ol' stuff . Link to comment Share on other sites More sharing options...
jsalicru Posted August 16, 2005 Share Posted August 16, 2005 2nd gear, then reverse... works all the time. I have to do it to my Civic Si too... "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
Strokemouth Posted August 17, 2005 Share Posted August 17, 2005 I have to do the same with my RS. The 2nd to reverse works about 40% of the time. Double-clutching works all the time. "They've done studies you know. Sixty-percent of the time, it works every time." Link to comment Share on other sites More sharing options...
warnoldscu Posted August 17, 2005 Share Posted August 17, 2005 try to shit ...... ...... MY EYES!!!!!!!!!! Link to comment Share on other sites More sharing options...
LGT Chris Posted August 18, 2005 Share Posted August 18, 2005 If it won't go in the first time, don't force it. Usually, just releasing the clutch and then back in will be enough to allow the transmission to go into reverse. Every manual transmission car I've own has been the same. 2005 Subaru Legacy 2.5 GT Luxomissle waGONE Link to comment Share on other sites More sharing options...
gfxdave99 Posted August 18, 2005 Share Posted August 18, 2005 If it won't go in the first time, don't force it. Usually, just releasing the clutch and then back in will be enough to allow the transmission to go into reverse. Every manual transmission car I've own has been the same. I had a cadillac CTS that had a synchro'd reverse but then again that was a really nice ZF trans.. (in regards to most cars) My acura TSX had a similar problem, a lil double clutch and everything was happy.. My friends 92x (aka) wrx does the same thing If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
