IGW Posted August 25, 2013 Share Posted August 25, 2013 What is everyone running as far as cold air intake setup? Any comments on function/price/fitment. ..... Link to comment Share on other sites More sharing options...
gimpydingo Posted August 26, 2013 Share Posted August 26, 2013 None. Unless you are putting down well over 300WHP, don't bother. Stock box/paper filter work perfect. If you must have one and are getting a tune for other parts as well, just steer clear of the SPT. Link to comment Share on other sites More sharing options...
IGW Posted August 26, 2013 Author Share Posted August 26, 2013 Ok thanks Link to comment Share on other sites More sharing options...
rtbrjason Posted August 26, 2013 Share Posted August 26, 2013 FWIW.. I'm pretty sure I was able to max my OEM intake out with a 16g on E85. I was scaling the maf and running out of air which I haven't seen happen before. I went with a KSTech 73mm and was able to get it scaled correctly. If you're hitting around 4.7 maf volts, you might need to upgrade. Otherwise I agree stock is your best bet. Link to comment Share on other sites More sharing options...
gimpydingo Posted August 26, 2013 Share Posted August 26, 2013 Are you running any mods now? Link to comment Share on other sites More sharing options...
IGW Posted August 26, 2013 Author Share Posted August 26, 2013 Not really, I just replaced the short block and had the heads rebuilt. I replace the turbo inlet with a perrin piece cause the factory was torn. So if there is no benefit from replacing the air box im not going to. I have a k&n filter inside the box and the car runs great so "if it aint broke don't fix it" Link to comment Share on other sites More sharing options...
gimpydingo Posted August 26, 2013 Share Posted August 26, 2013 Exactly. And you'll be told to dump the K&N as well. I finally bit the bullet and dumped mine; back to stock paper. Link to comment Share on other sites More sharing options...
IGW Posted August 26, 2013 Author Share Posted August 26, 2013 Why Link to comment Share on other sites More sharing options...
gimpydingo Posted August 26, 2013 Share Posted August 26, 2013 No power gains, and the KN element lets more debris through than stock paper. Link to comment Share on other sites More sharing options...
rtbrjason Posted August 26, 2013 Share Posted August 26, 2013 Agree with above.. Since there is nothing to gain, and it's worse for the motor, put a paper filter back in. Link to comment Share on other sites More sharing options...
IGW Posted August 26, 2013 Author Share Posted August 26, 2013 Ok thanks....it was in there when I got the car. It was also missing the scoop thst runs from the box to the top of the core support, should I get one or is it ok w/o it Link to comment Share on other sites More sharing options...
rtbrjason Posted August 26, 2013 Share Posted August 26, 2013 Perhaps previous owner had an aftermarket intake on it.. I would try to located the air ducting but it is not a mandatory part. Without it you will be sucking in much warmer air which will cause ignition timing to drop a bit. Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 ^ Yep, basically the car is already setup with a CAI. It sucks the ambient air right from the front of the grill. Not going to get much cooler. SR will just suck hot air from the engine bay. For what it's worth I've always run K&N until coming to this forum. We put 100k miles on our 07 2.5i Impreza, never used a drop of oil, car still ran great up until trade in. Only had to replace the struts on the front, pretty messed up roads in parts around here. The filter did add some noise to the Impreza, but that's about it. Plus having to clean/oil this filters, they take forever to dry. And if you over oil it can get on your MAF, giving you one more thing to check and clean. What kind of car do you have? If you are looking for sound there are plenty of cheap exhausts you can get, or just run the hawgzaust (sp). I ran the hawg for a while, sounded great, but got over it after a while. As soon as I stop being lazy I need to get my UP and a tune going. Link to comment Share on other sites More sharing options...
IGW Posted August 27, 2013 Author Share Posted August 27, 2013 2005 lgt... so basically I should install that scoop that comes over the rad for improved air temp Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 Yep, put that back to stock. Link to comment Share on other sites More sharing options...
IGW Posted August 27, 2013 Author Share Posted August 27, 2013 whats the hawgzaust? should these cars be tuned even after a cat back exhaust? Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 http://legacygt.com/forums/showthread.php/new-hog-zawst-system-sound-power-patented-washer-technology-35764.html Just making an exhaust leak to hear the subby sound. Cat back no, turbo back (downpipe) yes. Cat back or just new cans are an easy install. Link to comment Share on other sites More sharing options...
IGW Posted August 27, 2013 Author Share Posted August 27, 2013 what companys offer just the mufflers where they connect behind the rear diff? just that section of pipe on my exhaust is in terrible shape Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 There are quite a few axle backs Megan CNT (Invidia knockoff) Nameless Performance Probably can find user Perrins being sold on the forum Link to comment Share on other sites More sharing options...
IGW Posted August 27, 2013 Author Share Posted August 27, 2013 OK I read the thread on the exhaust bullshi......, dose it sound at all like an exhaust leak? Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 Sounds like an UELH subby! Classic sound for $2 in parts. I did drive for a bit with them off all together. Under WOT, WOW that is LOUD! Funny part is my wife would love to drive it around without mufflers, but the cops in CA wouldn't. Sounds good until you can find an exhaust you want. Personally I think I'm going with Invidia or Nameless for the cat/axle back and an Invidia down. High flow cat of course, bellmouth (not divorced). Link to comment Share on other sites More sharing options...
IGW Posted August 27, 2013 Author Share Posted August 27, 2013 I might try the washer deal later today after I finish my workload. I just don't want to hear the exhaust leak sound Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 It's a Subaru, won't sound like a lawmower honda or just a loud leak. If you like the beefy WRX/STI sound, this will give you that exact same thing. You can adjust the number of washers to help with the sound and drone. Truly I had no issues with it, liked the sound. Cheap and if you hate it, just put back. Plus you can get a look at how to install a new axle back, super easy. Link to comment Share on other sites More sharing options...
IGW Posted August 27, 2013 Author Share Posted August 27, 2013 ok...I let u know after I finish this BMW Valve cover. Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 Are you a mechanic or just an hobbyist? What type of BMW? This should give you an idea of the sound. [ame=http://www.youtube.com/watch?v=NpG2m65jjXQ]Subaru Legacy GT Megan Racing Exhaust - YouTube[/ame] [ame=http://www.youtube.com/watch?v=FghKdci3Gbg]Subaru Legacy GT exhaust sound - Hogzaust - YouTube[/ame] Link to comment Share on other sites More sharing options...
