legy outback Posted July 31, 2013 Share Posted July 31, 2013 Well, me and dad tore into my '98 legacy outback a little too quickly and we have all but the engine actually pulled out of the thing and realized the windows are down. Would I be able to simply reconnect the battery and roll the windows up without reconnecting all the electrics in that attached to the engine?? I would rather ask here than try the hard way Thanks in advanced guys!! Link to comment Share on other sites More sharing options...
Kennyfvholla Posted July 31, 2013 Share Posted July 31, 2013 Nope. I've done it a bunch of times. The only thing you might do is set off a few codes that will light the CEL. No harm will be done, and the ECU will be reset by the time you plug that battery back in after you put everything back together. Link to comment Share on other sites More sharing options...
legy outback Posted July 31, 2013 Author Share Posted July 31, 2013 THANK YOU!!! you did forget to mention that the alarm will go off on reconnecting...scared the crud out of my family after i ran out to roll the windows up at 12:30 am. lol But thanks a lot!!! Link to comment Share on other sites More sharing options...
mwiener2 Posted July 31, 2013 Share Posted July 31, 2013 Fuel can spray when you turn the key. Watch for that. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
spooln30 Posted July 31, 2013 Share Posted July 31, 2013 ^ Yep was just gonn say this. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted July 31, 2013 Share Posted July 31, 2013 Didn't know you had an alarm! And yeah, the fuel spraying thing.... I've had that happen once. I forgot to plug the hoses. It leaves a wonderful stain on blacktop lol Link to comment Share on other sites More sharing options...
legy outback Posted July 31, 2013 Author Share Posted July 31, 2013 Luckily we had the fuel hoses disconnected, and properly plugged...i suppose ill check on the heavy duty paper shop towels that we plugged them with lol and its all good Kennyfvholla. i spaced that i did too! Edit: SNAFU. it did squirt quite a bit of fuel into an apparently very well wrapped plug, i replaced it and all is well. It didn't even leak onto anything it was sitting on!! Link to comment Share on other sites More sharing options...
