b_betzold Posted July 24, 2013 Share Posted July 24, 2013 hey my 2.2l motor in my 95 legacy wagon is overheating but only when in traffic or idling, while driving its fine. i was thinking fan switch but not sure. maybe water pump?? any idea helps. thanks! Link to comment Share on other sites More sharing options...
pleaidestar Posted July 25, 2013 Share Posted July 25, 2013 http://legacygt.com/forums/showthread.php/need-help-overheating-211300.html Link to comment Share on other sites More sharing options...
pleaidestar Posted July 25, 2013 Share Posted July 25, 2013 ....and some good points in this one..gotta look around the forum a bit....http://legacygt.com/forums/showthread.php/overheating-passed-head-gasket-test-207030.html Link to comment Share on other sites More sharing options...
b_betzold Posted July 25, 2013 Author Share Posted July 25, 2013 basically check fuses. maybe add/burp coolent. or a coolent sensor.... well its a start Link to comment Share on other sites More sharing options...
pleaidestar Posted July 25, 2013 Share Posted July 25, 2013 Yes it is, do you have reason to believe your water pump or t-stat has failed, or had to remove your timing belt or have you done any recent work to your car? Typically when your heating up like in that situation means air..but the more info you give, the more prompt and logical responses will be received. Link to comment Share on other sites More sharing options...
adb140275 Posted July 25, 2013 Share Posted July 25, 2013 check to see if your fans are on when its anywhere above half way up the gauge.. you wont need the fans when you're moving, but if you sit still they need to kick on to keep it cool. i bet your fans are not working, nothing else will really cause the condition you describe. use a test light or multimeter to check for voltage at the fans when the engine is starting to get too hot. if theres voltage, the fans are bad. if theres no voltage, the switch is bad. Link to comment Share on other sites More sharing options...
pleaidestar Posted July 25, 2013 Share Posted July 25, 2013 i bet your fans are not working, nothing else will really cause the condition you describe really? The fans are needed but that is not the only cause guy Link to comment Share on other sites More sharing options...
adb140275 Posted July 27, 2013 Share Posted July 27, 2013 really? The fans are needed but that is not the only cause guy what else would cause exactly the condition he describes? it only overheats when the car is not in motion. the thermostat doesnt care if the car is moving, nor does the water pump unless the impeller is severely damaged somehow. then i'd imagine the cooling would be insufficient all of the time. Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 27, 2013 Share Posted July 27, 2013 Bubbles in the system can cause the car to overheat at idle in my experience. Purge the system again. Any time I drain the coolant I run the car in park or neutral for a while and watch the temp gauge. Make sure you are using an OEM Subaru thermostat. Link to comment Share on other sites More sharing options...
