imarock44 Posted August 14, 2005 Share Posted August 14, 2005 I have a strange problem my mechanic can't find. When travelling at/or above 40 mph I hear a strange tapping noise coming from the front end. It doesn't appear if I sit and rev the engine, if I coast or if I am in 2nd gear. Only when under load in 3rd gear. Any ideas? I'm thinking some kind of axel/transmission thing going on. I won't take it to the local Subaru dealers because of past problems...thanks Link to comment Share on other sites More sharing options...
emyselfandi Posted August 18, 2005 Share Posted August 18, 2005 could be transmission.. I guess you have check the cv boots/axles and belt pullies? I just had a rattle on my 95 but it was only when the car idled. It was the drivers side heat shield on the header. I'd check that too... good luck, Tim Link to comment Share on other sites More sharing options...
imarock44 Posted August 19, 2005 Author Share Posted August 19, 2005 Thanks Tim - turns out it was something with a cv axle. had one replaced awhile back and the mechanic who did the work didn't completely reconnect everything. my new mechanic found it and fixed it in no time. Link to comment Share on other sites More sharing options...
