dark_thorns Posted July 21, 2013 Share Posted July 21, 2013 So I finally get my car running again and installed a new clutch. The only problem is that when taking off from a dead stop in either reverse or first gear, the drivetrain feels like it's about to explode and the car shakes horribly. Sometimes it comes from the rear, sometimes from the front. It doesn't matter how clutchy i am with it, it still does it. But if the car is moving everything operates like it should. I had the flywheel turned, installed the clutch properly, and tightened everything down. I know i need a new master cylinder, but that wouldn't cause anything like this. Any ideas? Link to comment Share on other sites More sharing options...
subikid90 Posted July 21, 2013 Share Posted July 21, 2013 Check you u-joints, they can become stiff and cause an issue like you described -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
dark_thorns Posted July 21, 2013 Author Share Posted July 21, 2013 I'll get it up on the lift and check it out tomorrow. Link to comment Share on other sites More sharing options...
dark_thorns Posted July 21, 2013 Author Share Posted July 21, 2013 it almost feels as if the clutch is grabbing and releasing rapidly. Link to comment Share on other sites More sharing options...
snederhiser Posted July 21, 2013 Share Posted July 21, 2013 Hello; Check the clutch master and slave cylinder and make sure there properly bled and adjusted. Did you put in a new kit? I had to make new clip retainers for my throwout bearing. While on the lift, check tranny mounts. Steven. Link to comment Share on other sites More sharing options...
dark_thorns Posted July 23, 2013 Author Share Posted July 23, 2013 the u-joints feel good in it. i've got an oil leak from the rear of the oil pan, so i've got oil all under my car back to the trailer hitch so it seems i more than likely have oil all over the flywheel and clutch. Link to comment Share on other sites More sharing options...
