ashwinearl Posted July 10, 2013 Share Posted July 10, 2013 So I had a weird glitch this morning. I turned the car on and drove away with everything seemingly working fine. I tried to turn on the AC by pressing the AUTO button and got nothing. There was no power running to the front console so the radio or AC were not doing anything. The clock /temperature gauge were working as was the auto dim mirror, windows, lights, map lights. there was a CD in the 6 disc changer. I can't remember which button I pressed, either the LOAD or the EJECT button and it turned on. From that point on the console, radio/AC worked. I did change out the battery 2 nights ago. And I learned the hard way that an ECU reset procedure was needed which I did follow and it runs well now. Any thoughts? Link to comment Share on other sites More sharing options...
ashwinearl Posted July 10, 2013 Author Share Posted July 10, 2013 Never mind, I found the past threads on this issue. My initial search didn't come up with anything: http://legacygt.com/forums/showthread.php/radio-display-fix-142191.html Link to comment Share on other sites More sharing options...
