Daytona Posted July 8, 2013 Share Posted July 8, 2013 Hey all, New member here, just spent my hard earnt money on a 2007 Legacy 3.0R. Really great car and has been going awesome until a couple days ago when the following happened: - Was driving normally then check engine light came on - Was probably doing about 3 or 4k RPM was not driving hard - Cruise control and sports mode selector also was flashing - Bought a diagnostic scanner and found the code to be P0021 Other notable things: - Car has done about 103,000km - Oil has been changed at 100k Oil does seem to be leaking from the thread on that, check out below pictures. This is a 6 cylinder engine. It's not a fast leak, it's seeping slowly. Although when the check engine light came on and I got home (was only about 2km drive), I'd say I had to fill up at least 500ml of oil. Now I've located the AVCS solenoid and will be taking it out for a clean, but my bigger question is, what is the screw that you undo with an allen/hex key? I can't seem to find any posts that talk about that screw and what it's for, I'm guessing it controls oil flow/pressure. This is on drivers side, passengers side seems fine. EDIT: I have found this post: http://legacygt.com/forums/showpost.php?p=1943328&postcount=8 And that's really useful, but that seems to be off a 4 cylinder engine and if it's got a hex nut, it seems to be obstructed. Link to comment Share on other sites More sharing options...
Daytona Posted July 11, 2013 Author Share Posted July 11, 2013 A bit of a bump on the thread just to see if anyone knows what that hex nut is for. I ended up taking all the solenoids out and giving them a spray down with WD40, no error code since. But if anyone know's what this screw is for, would be really appreciated! Link to comment Share on other sites More sharing options...
