Stevo F Posted July 7, 2013 Share Posted July 7, 2013 I am having issues with my left turn signals fast blinking and was wondering what the procedure is to remove the plastic surround around the steering column as I suspect the turn signal switch needs to be cleaned or replaced. I saw where there are 3 screws on the bottom, but removing them did not loosen the plastic housing, so I really don't know what else is needed to remove the housing to get at the turn signal switch. Link to comment Share on other sites More sharing options...
johnegg Posted July 7, 2013 Share Posted July 7, 2013 I am having issues with my left turn signals fast blinking and was wondering what the procedure is to remove the plastic surround around the steering columnusually a fast blinking turn signal means you have a bulb burned out. check the bulbs. there are 4 screws on the bottom side of the column. make sure you get them all. two are very deeply recessed. one is right next to an access plug which can be removed. the top and bottom ''clip'' together so you may need to tap on it or pry it apart. but if you missed a screw, you will bust it. it is tricky working the bottom half off of the column adjust lever. check your bulbs. roanoke? Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 7, 2013 Share Posted July 7, 2013 Johnegg, he already checked he bulbs. The stalk gets all gunked up: http://legacygt.com/forums/showthread.php/help-turn-signal-switch-132545.html Link to comment Share on other sites More sharing options...
