SubaruLegacy93 Posted July 2, 2013 Share Posted July 2, 2013 Periodically, I have to pump my clutch pedal before I am able to switch gears. I have heard that the cluctch pedal is connected to the brake lines, and if the brake lines are dirty or whatever, then it will alter the pedal performance. Please help!! Link to comment Share on other sites More sharing options...
snederhiser Posted July 3, 2013 Share Posted July 3, 2013 Hello; Not sure which setup you have! Look at the back of the engine where it meets the bellhousing. You will see the clutch fork end sticking out on the top. If it has a cable replace it. If there is a hydralic slave cylinder, replace that and the clutch master cylinder. If a hose connects the slave cylinder and looks cracked, replace this. Be sure to bleed the system, Steven. Link to comment Share on other sites More sharing options...
