_NOAH_MR.NICEGUY_
    3
Everything posted by _NOAH_MR.NICEGUY_
  1. But my DAM is at a steady .50 and doesn't fluctuate. How bad is this? I'm running the economy mode map on my AP. Knock sensor does not vary either during WOT. Just replaced my turbo with a rebuilt stock vf40 and only have an Invidia up pipe and K&N panel filter. Just bought a turbo inlet but have not installed it yet, i'm pretty sure there's a boost leak, boost is inconsistent. Could the leak be the culprit?
  2. Thanks i'll try that. I checked the line with the regulator pill, shoulda checked the others while I was at it. How do I go about checking the BCS tho?
  3. I recently replaced my turbo in my 06 and upgraded to an invidia up pipe. It's a rebuilt vf40 from Hill Country Forced Induction. Everything seems to drive fine and i'm not getting any codes, but i'm barely getting boost. It's maybe getting 5psi. I've checked for leaks and don't hear anything abnormal. But my turbo inlet is looking pretty shitty. It was fine when I installed the new turbo, no rips or tears, but now its looking a little shot. Could that be a reason i'm not making boost? Or is it a vacum line i'm not checking? Restrictor pill seems fine and I cleaned my MAF sensor. AP shows my wastegate duty is fine.
