Hybrid22L
    100
Everything posted by Hybrid22L
  1. I'll adjust the headlight tonight. I think the bulb was bad. I dropped in the 85122+ and it was fine this morning. We'll see what happens.
  2. Here is a pic of the setup Rigo did for me. Denso Slim Ballast 85122+ bulbs rx330 bowls Legacy Shield Legacy Lens Holder Celica Clear Lenses Used 2 washers on both side Let me know if you think I need to adjust the headlights at all. http://i190.photobucket.com/albums/z310/hybridsti/IMG_9703.jpg
  3. stock wiring harness that has been modified. DRL disabled as well. I think it may be the bulb. I'm going to chnage out the bulb and try driving it tomorrow to see what happens.
  4. What should I be looking for? The driver side is fine. Damn passenger side. Wiring was done the same for both side.
  5. i'll probably shoot pics tonight of the setup rigo did. Just have to figure out why my passenger side headlights shuts off. If I completly turn off my headlights and turn them back on, my lights are fine. Then after driving for a while. The passenger side will turn off again. I did melt some plastic on the bulb. :spin:So I'm thinking this may be the problem. Going to replace the bulbs tonight with spares and see what happens.
  6. FYI. the denso slim do not disconnect. I found that out the hard way on friday. Rigo had the cut the connector and resolder it. The retro turned out awesom and i need to take pics to post up. The cutoff and color are awesome. Its amazing what the celica lenses can do.
