Boulderguy Posted September 24, 2005 Share Posted September 24, 2005 Yet another reason to crawl under the dash with wirecutters... Finally found the wire that controls the trunk lock relay, have wired it to the driver's door lock/unlock relay along with the passenger doors' unlock relays as well. Now the whole car unlocks with one button push (or one squat in your tight pants, Hasslehoff). EDIT - This mod is for the OB/Leg. wagon, not a sedan. This DOES NOT "open" the hatch, it merely unlocks it. If you're anything like me, your trunk is always locked at the most inconvenient time b/c it didn't unlock with the doors the last time you hit that button. This solves that issue. Why Subaru designed it this way I've no idea. So if you haven't wired the passenger door relays into the driver's door yet, I'm borrowing a previous post for those instructions. This will make all four doors unlock the first time you push "unlock" on the keychain remote - http://www.legacygt.com/forums/showthread.php?t=2972 Once you've got that piece knocked out, you're basically going to do the same thing with a 2nd wire - it's the white with black stripe that's right behind the lite green wire, 1 terminal inward from the end on the center row of terminals. Bear in mind that I'm working with an '05 OBXT, haven't tried this on any other cars. There's another wire close by that's white/green I think, DON'T cut that one. Clip the white/black wire about an inch & a half from the connector (in case you want to reconnect later)(you'll probably have to strip away the tape wrap to do this) and connect it to the light green wire used before. That's it - your trunk will now unlock with your driver's door (& passengers' if you did that too). The lock function remains unchanged. Bonus points - I've now got 2 positive triggers from the key remote that aren't being used. I thought about rigging them to open/close the sunroof remotely, but haven't taken the time to do it. I do know the sunroof switch in the headliner works on negative triggers to the relay, and the relay is on IGN+, not constant+, so this would take some work. Anybody up for it? Link to comment Share on other sites More sharing options...
John M Posted September 25, 2005 Share Posted September 25, 2005 Why would you want to open the trunk every time you unlock your doors? Do you have to do something in your trunk before you can drive your car? Link to comment Share on other sites More sharing options...
OCDetails Posted September 25, 2005 Share Posted September 25, 2005 I can think of absolutely no practical reason that one would want their trunk to open every time they unlocked their doors, but I guess you find that useful. Figure out a way to close the windows and the sunroof when you lock the doors and you'll be my new hero. That is something I can see being useful. ...unless you are leaving your windows cracked for a reason. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
laz Posted September 25, 2005 Share Posted September 25, 2005 The windows roll up should not be too hard, just need to buy the DEI modules and somehow use the output of the second push to activate it. X --- Link to comment Share on other sites More sharing options...
forestir Posted September 25, 2005 Share Posted September 25, 2005 Some people throw a briefcase or whatever into their trunks every work day, so this could come in handy. Either in the trunk or on the backseat, so either mod would be handy. Thanks for the info! Link to comment Share on other sites More sharing options...
meier motor sports Posted September 25, 2005 Share Posted September 25, 2005 since he has an outback xt im thinking its a wagon. on the wagon when u press the trunk button on the key fob. it unlocks the trunk. it does not pop open. jsut like if u unlocked a regular door Link to comment Share on other sites More sharing options...
forestir Posted September 25, 2005 Share Posted September 25, 2005 since he has an outback xt im thinking its a wagon. on the wagon when u press the trunk button on the key fob. it unlocks the trunk. it does not pop open. jsut like if u unlocked a regular door That's correct. Pressing the 3rd remote button merely unlocks the hatch, but doesn't open it. I'd agree that it wouldn't be desirable to open the trunk on a sedan each time you unlocked the car. Link to comment Share on other sites More sharing options...
Boulderguy Posted September 25, 2005 Author Share Posted September 25, 2005 Maybe I should clarify that - I'm in the OB wagon, not a legacy sedan. This DOES NOT "open" the hatch, it merely unlocks it. The trunk hatch on wagons requires a seperate remote button be pushed to unlock the trunk, it doesn't unlock with the doors. What really irritated me about it was the doors would typically be unlocked but the hatch typically stayed locked, unless I had a reason to hit that button since locking them the day before, for example. So I'd come out to the car with two armloads of stuff & manage to get a hand on the trunk handle only to find it's locked - then I have to balance everything while I dig out my keys to hit the seperate button. That make more sense? This must have sounded pretty bizarre to y'all with sedans... About the DEI module - sure, that could be rigged up w/o much trouble, but the pieces are already in there (relays, timers, etc) so it could be done with the simple addition of 2-3 SPDT relays & some wire-finding, about $10 total. something tells me there's an even simpler way to rig the existing relays & make it happen, but I lack the patience to try it. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 25, 2005 Share Posted September 25, 2005 The delaer can make it so you unlock all 4 doors and hatch with one push. It says so in the manual. Then you don't need to hack wires. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Boulderguy Posted September 25, 2005 Author Share Posted September 25, 2005 Problem is, no one can find a dealer who knows how to do this! The same issue came up in the post I referenced & was debated into the ground. http://www.legacygt.com/forums/showthread.php?t=2972 This mod takes maybe 15 min, less than the driving time to the dealer & back for me. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 25, 2005 Share Posted September 25, 2005 No one could find a dealer that knew how to do teh ECU rflash...until we told them about it. Tell the dealer to plug in their Subaru Select Monitor Tool and select the option than hit ok. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
jerami1981 Posted September 25, 2005 Share Posted September 25, 2005 You can get your windows to do that buddy I can think of absolutely no practical reason that one would want their trunk to open every time they unlocked their doors, but I guess you find that useful. Figure out a way to close the windows and the sunroof when you lock the doors and you'll be my new hero. That is something I can see being useful. ...unless you are leaving your windows cracked for a reason. Link to comment Share on other sites More sharing options...
PolarDog Posted October 21, 2006 Share Posted October 21, 2006 Yes, yes, it has been over a year since anyone posted on this topic, but I must say, that I did the mod and installed a switch. Now I can unlock all the doors and the trunk with a single press. I can also flick the switch and return it to the original "double-press-unlocks-everything" mode. Not sure, but methinks that the Subaru Select Monitor solution does not offer this... Curious why this couldn't be programmed into the stock nav system... Anyway, thanks for the info Boulderguy! PolarDog Link to comment Share on other sites More sharing options...
forestir Posted October 21, 2006 Share Posted October 21, 2006 The delaer can make it so you unlock all 4 doors and hatch with one push. It says so in the manual. Then you don't need to hack wires. It seems dealers are rather lame about this. They either pretend (?) that they never heard of it, or they want to charge you 1/2 hr labor. Lame. Link to comment Share on other sites More sharing options...
mwiener2 Posted October 21, 2006 Share Posted October 21, 2006 it's in the manual that it can be done....therefore, it can be done without hacking wires. I've had the car for almost 2 years now and I've never had a problem with hitting the button twice and I'm also still on the original keyfob battery. This is a stupid mod that isn't worth the hackjob. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PolarDog Posted October 22, 2006 Share Posted October 22, 2006 it's in the manual that it can be done....therefore, it can be done without hacking wires. I've had the car for almost 2 years now and I've never had a problem with hitting the button twice and I'm also still on the original keyfob battery. This is a stupid mod that isn't worth the hackjob. mwiener, Thank you for your kind words and your guidance. Unfortunately, I am not as lucky with the remote as it appears you are. It sounds like the performance of your keyfob is predictable and consistent, which makes me jealous. As far as the documentation is concerned, yes, if it is printed, then there is a good chance that it is true. It also sounds like you have great success with the capabilities of your dealer and again I am jealous. Thanks again for your concerns. PolarDog Link to comment Share on other sites More sharing options...
Mach Posted October 22, 2006 Share Posted October 22, 2006 mweiner, if you can tell me where the option is in the SSM options, I'll unhack and head back to the dealership. The option for unlocking all doors at once appears to only be possible on European model cars. While hooked up to the SSM, any option that might affect door locks was not accessible (this is on an OB 06 XT). Below are the options, I believe that I still have the dealership screenshot that shows which are accessbile that I can scan if that helps. Link to comment Share on other sites More sharing options...
Boulderguy Posted October 22, 2006 Author Share Posted October 22, 2006 This is a stupid mod that isn't worth the hackjob. You think splicing 2 wires is a hack job? Have you looked at your list of mods lately? What's wrong with you? So please silence us all with your wisdom by pointing to someone - anyone - on this forum who has successfully accomplished this mod thru a dealer. Link to comment Share on other sites More sharing options...
mwiener2 Posted October 22, 2006 Share Posted October 22, 2006 This mod is a hack job becasue all it is doing is saving you from pressing a button a second time. If you're really that lazy that you can't press the buttton a second time, maybe you need to get out more. And none of my mods are hackjobs....All of them have a clear and concise purpose that could not be acomplished any other way. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Boulderguy Posted October 22, 2006 Author Share Posted October 22, 2006 The purpose of any mod is to better adapt the car to the individual's taste or purpose whatever that may be. If you don't like it don't do it, but don't be a jackass & judge someone b/c you don't like their mod. My God you're a weenie. Link to comment Share on other sites More sharing options...
mwiener2 Posted October 22, 2006 Share Posted October 22, 2006 so, you're a lazy bum My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PolarDog Posted October 23, 2006 Share Posted October 23, 2006 Man o man... Hey, sorry for any offense to anybody. I just wanted to say thanks for the info on this link as it worked out very well for me and my situation, and to say that I will be building on what I have learned here for another mod (involving auto-up windows and the actuation of the windows with the remote) So many ways to solve a problem, I know. Some work better than others for me. Please take no offense if I didn't get yours to work... So much pain and anger... ...ugh PolarDog Link to comment Share on other sites More sharing options...
obxt Posted November 4, 2006 Share Posted November 4, 2006 I've got an '05 OBXT, and I just did the mod (splicing both wires). Super easy and it works great for unlocking all 4 doors and the trunk. BUT one problem. Now when the doors are locked, the security light flashes about every half second for about a minute, then it flashes twice every 3 seconds. When the doors are unlocked, the security light flashes once about every 3 seconds. When the key is in the ignition, the light does not flash. When I deactivate the alarm, it seems to work normally (putting it in "valet mode", with the security light flashing every 3 seconds whether the doors are locked or unlocked.) Has anyone else had this problem or any ideas on how to fix it? Link to comment Share on other sites More sharing options...
Boulderguy Posted November 4, 2006 Author Share Posted November 4, 2006 Maybe you're stuck in Valet mode? Check the manual. Link to comment Share on other sites More sharing options...
obxt Posted November 4, 2006 Share Posted November 4, 2006 Maybe you're stuck in Valet mode? Check the manual. I thought that might be it, but I took it in and out of valet mode several times, and I'm still getting the flashing even when it's out. When it's in valet mode, the flashing seems to be "normal" (once every 3 seconds). When it's out, the flashing is like valet mode when unlocked, but different when locked (once every half second at first, then twice every 2 seconds) Link to comment Share on other sites More sharing options...
