KurtP Posted August 23, 2009 Share Posted August 23, 2009 are they any better than what comes on the LGT's? Link to comment Share on other sites More sharing options...
TPLGT Posted August 23, 2009 Share Posted August 23, 2009 Short answer. No Rehab is for quitters. Link to comment Share on other sites More sharing options...
praedet Posted August 23, 2009 Share Posted August 23, 2009 ^^^He is wrong. The WRX brakes are both red and have a total of 20 pistons if add up all the calipers. Ours are gray and only have 6. Obviously the red 20 piston brakes are better Link to comment Share on other sites More sharing options...
TPLGT Posted August 23, 2009 Share Posted August 23, 2009 ^^^He is wrong. The WRX brakes are both red and have a total of 20 pistons if add up all the calipers. Ours are gray and only have 6. Obviously the red 20 piston brakes are better Are you really trying to tell me the wrx brakes.....they're pretty... Are better? I will lett others chime in. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Impulse Posted August 23, 2009 Share Posted August 23, 2009 no they're not better, look at the rotor size (diameter and thickness) and pad area. ours are superior in every way. the ONLY thing you might gain is better pedal feel-not worth the money. you're better off going SS brake lines for the feel. Link to comment Share on other sites More sharing options...
praedet Posted August 23, 2009 Share Posted August 23, 2009 You are both wrong, 20 vs 6, red vs gray Link to comment Share on other sites More sharing options...
dudeondacouch Posted August 23, 2009 Share Posted August 23, 2009 This has been gone over before. They are a downgrade. Link to comment Share on other sites More sharing options...
JSK05LGT Posted August 24, 2009 Share Posted August 24, 2009 Unlike your avatar which is obviously an upgrade dudeonacouch :o) Link to comment Share on other sites More sharing options...
