Kellen Woodfield Posted January 8, 2009 Share Posted January 8, 2009 Hi i am new to this site. i drive a 2008 legacy se with manual climate control. its just got the two knobs nothing fancy. what i am looking to do is remove the original bezel and stock radio and replace it with a double din bezel to allow an aftermarket touchscreen head unit. would someone be willing to walk me through the steps of removing the trim and bezel correctly so that i dont break anything. also is there anything i would have to worry about as far as the climate control goes or will that not be affected? please help because i would like to do this soon. thank you. kellen Link to comment Share on other sites More sharing options...
f1anatic Posted January 8, 2009 Share Posted January 8, 2009 Kellen. http://www.legacygt.com/forums/showthread.php?t=6216&highlight=vacation+pictures If you do your own search for vacation pix, you may have several hits and they may show our family pictures from different years. Select the year you like the most - but there should not be any major differences. We all traveled the same places. The pictures that I linked you to are from our 2005 trip. Just trust me. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 8, 2009 Author Share Posted January 8, 2009 i went through every link on this forum and not 1 page could be found.. help? Link to comment Share on other sites More sharing options...
el5y Posted January 8, 2009 Share Posted January 8, 2009 http://www.trabbic.com/legacy/radio%20install.pdf Link to comment Share on other sites More sharing options...
f1anatic Posted January 8, 2009 Share Posted January 8, 2009 Well sorry man. The vacation pictures are no longer working. They are the code name for the assembly-disassembly manual for the car. The PDF above comes from the full manual. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 8, 2009 Author Share Posted January 8, 2009 thanks el5y that is a start Link to comment Share on other sites More sharing options...
el5y Posted January 8, 2009 Share Posted January 8, 2009 http://www.crutchfield.com/p_120998901/Subaru-Legacy-Outback-In-dash-Receiver-Kit.html?tp=3121 Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 8, 2009 Author Share Posted January 8, 2009 yea that is similar to the piece i ordered except mine is double din. im just trying to get some detailed pictures of the easiest and safest way to take of the plastic trimming without breaking anything or doing damage to anything.. Link to comment Share on other sites More sharing options...
RayC Posted January 9, 2009 Share Posted January 9, 2009 Manual Trans or auto? Not sure about the auto, but for the manual turn the shift knob counter clockwise (righty tighty, lefty loosy) until you can feel the knob seperate from the gear shift lever, then pull the plastic piece around the shifter up by grabbing the plastic on the rear part of the boot (basically put your fingers under the boot and pull up). This piece will pop up from the rear, then down and out from the front. Disconnect the wiring going to the ash tray, then remove the two phillips screws (left and right, one per piece) on the two trim pieces to the left and right of the stereo. Once those are out you will see 6 (maybe 4 with manual climate control) phillips screws holding the factory head unit in. Remove those and the unit should come right out. Hope that helps. where in CT are you? Link to comment Share on other sites More sharing options...
2dar3 Posted January 9, 2009 Share Posted January 9, 2009 waterbury Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 9, 2009 Author Share Posted January 9, 2009 its automatic so i cant get under the boot like in a manual car.. any other way to begin this process? Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 10, 2009 Author Share Posted January 10, 2009 ok so i just went out, i got the ring around the shifter off, i got the plastic around the shifter off, i got the trim up the sides off, and i took the screws out of both sides of the stereo but i cant get the stereo to slide out. any tricks or did i miss a step? Link to comment Share on other sites More sharing options...
RayC Posted January 10, 2009 Share Posted January 10, 2009 Did you get all of the screws? It should just slide out. Link to comment Share on other sites More sharing options...
zmarko Posted January 10, 2009 Share Posted January 10, 2009 Did you get all of the screws? It should just slide out. He's got the manual climate controls, and I've heard that they don't come out as easily. I'll try and find a thread about it. Link to comment Share on other sites More sharing options...
zmarko Posted January 10, 2009 Share Posted January 10, 2009 This thread might help the OP. Dunno. http://www.legacygt.com/forums/showthread.php?t=88020&highlight=manual+climate Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 10, 2009 Author Share Posted January 10, 2009 zmarko i dont see how that thread applies. im sorry. i took out 4 screws on each side of the radio and it still wouldnt even budge. i dont want to force it out and break anything. could you try and walk me through what you think i need to do Link to comment Share on other sites More sharing options...
RustyShackleford Posted January 10, 2009 Share Posted January 10, 2009 zmarko i dont see how that thread applies. im sorry. i took out 4 screws on each side of the radio and it still wouldnt even budge. i dont want to force it out and break anything. could you try and walk me through what you think i need to do I'm not sure how the '08 compares to '05-'07, but it sounds to me a little like you missed the screw (on each side) that is recessed back a couple inches, and maybe removed two (on each side) that hold the dash together and don't want to be removed. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 11, 2009 Author Share Posted January 11, 2009 I'm not sure how the '08 compares to '05-'07, but it sounds to me a little like you missed the screw (on each side) that is recessed back a couple inches, and maybe removed two (on each side) that hold the dash together and don't want to be removed. ok yea there are 2 screws that are recessed back a ffew inches behind the stereo trim. i wasnt sure if i should remove those because on all the previous forums no one mentioned those screws needing to be removed. but i will give that a try and let you know if that does the trick. thank you for the input. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 14, 2009 Author Share Posted January 14, 2009 thanks everyone that was the trick.. will post a pic when im all done doing the mod.. Link to comment Share on other sites More sharing options...
cino135 Posted January 21, 2009 Share Posted January 21, 2009 what headunit/screen are you putting in? and where did you get your bezel for it? opening size? etc etc. Link to comment Share on other sites More sharing options...
Kellen Woodfield Posted January 23, 2009 Author Share Posted January 23, 2009 i put in a 6.1 inch touchscreen kenwood headunit. i got the bezel through my audio dealer in new mexico its made by scoshe. u iso fit the headunit. Link to comment Share on other sites More sharing options...
