Nightmaresmk Posted June 4, 2013 Share Posted June 4, 2013 (edited) Put your Wheel specs Tire size and Lowering setup or stock Rub I'll Start 17x8 et 35 rota torques 255/50R17 Hankook Ventus Stock Drivers side front fender wheel slightly on right turns. http://imageshack.us/a/img27/2269/img20130502083350279.jpg Edited May 12, 2014 by Nightmaresmk Link to comment Share on other sites More sharing options...
SupraLegacy Posted June 7, 2013 Share Posted June 7, 2013 Wheels: XXR 527 18x8.75+35 Tires: Pirelli Pzero Nero 245/40/R18 Suspension: ISC Coilovers Rub/Cut: Cut Rear Metal inner fender no more rub. Other: Removed Rear bump-stops/helpers http://farm3.staticflickr.com/2863/8896299338_28a02319e6_h.jpg http://farm9.staticflickr.com/8407/8896299956_5513fc19a7_h.jpg Bryan C. NorCal - SupraLegacy - 05 LGT Wagon 5MT - 15 FXT Premium Link to comment Share on other sites More sharing options...
Heffernan Posted June 7, 2013 Share Posted June 7, 2013 ^ that looks so nice. Link to comment Share on other sites More sharing options...
kongzilla Posted June 10, 2013 Share Posted June 10, 2013 Wheels: 17x7.5 50+ Volk CE28 Tires: Falken Sinceras Touring 225/55/17 Suspension: JDM Spec B Rev A Blistien shocks/struts and JDM Spec B Rev A springs Rub: Zero rub http://i1250.photobucket.com/albums/hh527/Jimyang/Subaru%20Outback/IMG_7990_zps77d57418.jpg Link to comment Share on other sites More sharing options...
OutbackXT05 Posted June 11, 2013 Share Posted June 11, 2013 Wheels: 18x8.75 +35 XXR 530s Tires: Hankook V12 Evo 255/40/18 Fenders: Hacked, Cutted, Painted (No rubbing) http://i622.photobucket.com/albums/tt307/fibtlcivic/334366_476753319023736_1619181657_o.jpg http://i622.photobucket.com/albums/tt307/fibtlcivic/7796622408_9d5847bcbd_k-Copy2.jpg Link to comment Share on other sites More sharing options...
kongzilla Posted February 10, 2014 Share Posted February 10, 2014 Bump this up Link to comment Share on other sites More sharing options...
Nightmaresmk Posted February 13, 2014 Author Share Posted February 13, 2014 when i get new wheels and tires i will bring my anti tuck. Link to comment Share on other sites More sharing options...
Dodik Posted February 17, 2014 Share Posted February 17, 2014 Wheels:02-03 wrx stockers 16x6.5 (et53 iirc) Tires: Kumho 225/60/16 Suspension: Stock Rub/Cut: None http://i88.photobucket.com/albums/k163/kazantip/SNV31686.jpg Wheels: No name 18x7.5 +40 Tires: 245/45/18 Micheline alpines Suspension: Stock Rub/Cut: None http://i88.photobucket.com/albums/k163/kazantip/DSC00004.jpg Wheels: 08-09 Outback XT wheels 17x7or6.5 Tires: 225/55/17 Suspension: Stock springs legacy struts -1" Rub/Cut: Slight rubbing on bottom of front spring perches http://i88.photobucket.com/albums/k163/kazantip/CAR014.jpg Wheels: Drag DR-19 18x7.5 et45 Tires: 245/45/18 Micheline alpines Suspension: Stock springs legacy struts -1" Rub/Cut: Slight rubbing on bottom of front spring perches http://lh3.ggpht.com/_9KLQIfKrwMM/TQYT9ADwuiI/AAAAAAAACWk/VYPBpACAu_4/s640/IMG_1225.jpg Wheels: Drag DR-19 18x7.5 et45 Tires: 245/45/18 Micheline alpines Suspension: Ohlin PCV Coilovers Rub/Cut: None Other: Cut bump stops in half http://i88.photobucket.com/albums/k163/kazantip/2012-02-26105954.jpg Wheels: 08-09 Legacy wheels 17x7or6.5 Tires: 225/55/17 Suspension: Ohlin PCV Coilovers Rub/Cut: None Other: Cut bump stops in half http://legacygt.com/forums/attachment.php?attachmentid=165267&d=1381761511 Link to comment Share on other sites More sharing options...
Rester5350 Posted February 18, 2014 Share Posted February 18, 2014 This is my old setup. Bbs Rgr 17x7.5 -48 Potenza s04 pp 225/45/17 Koni / Epic with whiteline bushings and spec b upper control arm. No roll, pull or rub. Tires are too small for that. Link to comment Share on other sites More sharing options...
garage1217 Posted May 12, 2014 Share Posted May 12, 2014 (edited) Not lowering - going up It is an outback after all Wheels: 02 wrx Tires: 215/70/16 toyo open country ATII Suspension: Installing this weekend - King Spring rears - 3/4 lift spacers - uprated rear KYB's from primitive and front KYB oe replacements (stock shown) Rubbing or issues: Zero at stock outback height. Can turn full lock - no rubbing. http://www.garage1217.com/SUBARU/TIRES%205-3-14/2.JPG http://www.garage1217.com/SUBARU/TIRES%205-3-14/4.JPG Edited May 12, 2014 by garage1217 Link to comment Share on other sites More sharing options...
WhiteyGluck Posted February 14, 2016 Share Posted February 14, 2016 Hope to see more entry's. This is very helpful. Thankyou Link to comment Share on other sites More sharing options...
Cale Posted March 23, 2016 Share Posted March 23, 2016 Wheels: 5x100 STi BBS 17x7.5 +53 Tires: Potenza S-04 225/45r17 BC Racing coilovers No rubbing http://i.imgur.com/oaMiCql.jpg?2 Test fitting 25mm spacers: http://i.imgur.com/Zipacjg.jpg?1 Link to comment Share on other sites More sharing options...
housemusic1 Posted March 23, 2016 Share Posted March 23, 2016 Test fitting 25mm spacers: http://i.imgur.com/Zipacjg.jpg?1 How long have you been running the spacers? Any issues of any kind? Link to comment Share on other sites More sharing options...
Cale Posted March 24, 2016 Share Posted March 24, 2016 Haven't run them at all. The car has been down for a engine rebuild since shortly after that picture. Need to do fender work as you can tell. Link to comment Share on other sites More sharing options...
xtea Posted March 24, 2016 Share Posted March 24, 2016 nlmotoring has a sale on XXR's right now. I'm going to pull the trigger on some 18" 530's in silver. Do I want +20 or +33? I will be lowering on outback bc br's. Link to comment Share on other sites More sharing options...
Cale Posted March 25, 2016 Share Posted March 25, 2016 What width are you looking for? Link to comment Share on other sites More sharing options...
Thomistopheles Posted March 25, 2016 Share Posted March 25, 2016 Wheels: XXR 531 18x8.5+33 Tires: 245/45r18 Suspension: ISC N1 coilovers, -2°F -1°R camber Fenders: Trimmed, rolled, pulled http://i489.photobucket.com/albums/rr260/TurboThom/A24E2571-Edit_zps5k4zsdvy.jpg http://i489.photobucket.com/albums/rr260/TurboThom/A24E2531_zps2dnlagxn.jpg http://i489.photobucket.com/albums/rr260/TurboThom/A24E2491_zps5gpa71vi.jpg Wheels: AT Italia Rivas 17x8+35 Tires: 225/55r17 Blizzak WS80 Suspension: ISC N1 coilovers, -1°F -1°R camber Fenders: Trimmed, rolled, pulled http://i489.photobucket.com/albums/rr260/TurboThom/A24E1631-Edit_zps3hx65xm7.jpg http://i489.photobucket.com/albums/rr260/TurboThom/A24E1624-Edit_zpsp1ab6ggs.jpg Link to comment Share on other sites More sharing options...
Stevh0 Posted August 9, 2016 Share Posted August 9, 2016 MRW 5x100 17x7.5 +48 Nexen n7000 215 55 17 No rubbing. Oem suspension http://uploads.tapatalk-cdn.com/20160809/0365710c25d46d3ad476c50bed7d6f2a.jpg Link to comment Share on other sites More sharing options...
kaitanium Posted March 31, 2019 Share Posted March 31, 2019 would like to bump this up to see what else people are running on their OBs. Thinking about running 18x8.5 on 245/40. Not sure about what offset is good if im lowering on BC racing coilovers. Link to comment Share on other sites More sharing options...
Eivind Posted April 2, 2019 Share Posted April 2, 2019 Summer setup: Fifteen52 Turbomac 18x9.0 ET30 Toyo Proxes Sport 235/40-18 Winter setup: Fifteen52 Tarmac 18x8.5 ET30 Michelin X-Ice Xi3 215/45-18 Link to comment Share on other sites More sharing options...
kaitanium Posted May 14, 2019 Share Posted May 14, 2019 bumping this back from the grave to see what else people are running. Looking at ET 42 or 44s for my car on 245/40 or maybe even 245/45 if anyone has that lowered. Really want to make sure no rub. Link to comment Share on other sites More sharing options...
Rhitter Posted May 14, 2019 Share Posted May 14, 2019 (edited) Are you stock height? if so, 245/45/18 should be fine. You may rub on the inner rear fender liner depending on wheel / tire width. If lowered all bets are off. I was rubbing with the stock wheels. 235/45/18 is a better choice if you want to be sure of 0 rub. Edited May 14, 2019 by Rhitter My OBXT build Link to comment Share on other sites More sharing options...
FutureFicus Posted May 14, 2019 Share Posted May 14, 2019 (edited) It's been a while...currently shopping for tires again after getting a flat. Koni's - Stock Legacy springs Front & Stock Outback springs Rear 245/45/18 on 18x8.75 +33 Hankook Ventus V12 Evo (about 3 years old) Fender's rolled and liner trimmed. Edited May 14, 2019 by FutureFicus image embed Link to comment Share on other sites More sharing options...
lilredwagon Posted May 22, 2019 Share Posted May 22, 2019 Here's what 18x8.5 et40 looks like on Swift Springs (+3/4" spacer in the rear) on an OBXT. Tires are 245/45/18 and fenders are cut under the stock flares: Link to comment Share on other sites More sharing options...
kaitanium Posted May 25, 2019 Share Posted May 25, 2019 (edited) Are you stock height? if so, 245/45/18 should be fine. You may rub on the inner rear fender liner depending on wheel / tire width. If lowered all bets are off. I was rubbing with the stock wheels. 235/45/18 is a better choice if you want to be sure of 0 rub.Yea we spoked before. I've asked a ton of people and seems like the average is 245/40/18x8.5 with no rub (random offsets, no average there but none lower than 44). Haven't heard one with a 235 yet. All depends on offset and how low you go no? 235 is on a 8in wide rim? That would open more rim choices up for sure. Wanted to go as wide as I can obviously which is why I was planning 8.5. Planning on bc racing coilovers. If you look up Instagram user 6mt_obk thats how low I want to go. Just a nice wheel arch gap all around. He's running 245/40/18x9 et40 with no rub and uncut liners and not rolled. Instagrammer karas_obxt is running 245/40/18x8.5 et44 with only rub in front right because of a nose dive problem(?), Uncut unrolled. Both running bc racing coilovers. Kara's is a bit lower than I'd like. Stock wheels on a lowered car at et48 definitely sounds like it could rub on the inner tire or maybe at full lock on the fronts Edited May 28, 2019 by kaitanium Link to comment Share on other sites More sharing options...
