Adam393 Posted May 22, 2013 Author Share Posted May 22, 2013 No, they are separate options. You can get billet, minus STS, or vice versa (I think) Link to comment Share on other sites More sharing options...
Drew888 Posted May 22, 2013 Share Posted May 22, 2013 Friend of a friend has their 20g with both wheel upgrades with a td05 7cm housing and the powerband is beautiful. Made 380/390 on a mustang dyno. Hits 350tq at 3300 and doesn't drop below till around 5500. td05 7cm 20g on a heartbreaker making 380? I realize they are only numbers but I've been around a while and have yet to see this. Some mod details are missing. Great turbos though... if only they were BB. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
need bb Posted May 22, 2013 Share Posted May 22, 2013 Do you have the bigger fuel pump and injectors to support the 20g ? I know mustangs read low but 290whp ? Yes DW850 and 255L FP. I was really hoping for more than 290WHP, but my stock clutch and IPR TMIC are probably holding me back. The car's making about 25WHP more than a VF52 or VF48 and the turbo has more room left in it. I expect a TD05 20G to make about 30-40WHP more than a VF48 so I think I am in the ballpark. Link to comment Share on other sites More sharing options...
system60 Posted May 22, 2013 Share Posted May 22, 2013 (edited) td05 7cm 20g on a heartbreaker making 380? I realize they are only numbers but I've been around a while and have yet to see this. Some mod details are missing. Great turbos though... if only they were BB. Nothing else crazy done to it, he listed the graph and mods in the kinugawa post in ppb on nasioc. Car was tuned at PAS, an STi with a Hta green made 350hp/346tq for comparison which just makes the other results stranger. More than anything I'm envious of the plot Edited May 22, 2013 by system60 Link to comment Share on other sites More sharing options...
lordchilly Posted June 1, 2013 Share Posted June 1, 2013 the turbo came in. Cant wait to install this. Looks very nice. [/img] Link to comment Share on other sites More sharing options...
slonez Posted June 2, 2013 Share Posted June 2, 2013 I'm on Kamak TD05-20G. Absolutely love it! Link to comment Share on other sites More sharing options...
510Finn Posted June 2, 2013 Share Posted June 2, 2013 Anyone here running this? I'm considering going with the TD06SL2 8cm 20G PnP with billet compressor wheel, FiveO Motorsports 1200cc EV14 and Aeromotive 340 and tuned for E85. 08 Spec B details Link to comment Share on other sites More sharing options...
Drew888 Posted June 3, 2013 Share Posted June 3, 2013 Only considering? [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
510Finn Posted June 4, 2013 Share Posted June 4, 2013 Yes, because there are several alternatives to consider. I found out that the Kamak is their higher end line and comes with STS 9 blade turbine and not available on the Kinugawa turbos. I also found out that from the GB (SteamSpeed) that the price is around 300 more for these. The port and polish option from the GB is only on the turbine side which is okay, but then there also is no ceramic coating options either. So now I'm looking at a BB equivalent with all the options I mentioned (no STS turbine because its not Kamak or Kinugawa) but full port/polish (turbine and compressor sides) and ceramic coating. Search on 6StarSpeed for more details. 08 Spec B details Link to comment Share on other sites More sharing options...
Drew888 Posted June 5, 2013 Share Posted June 5, 2013 Impressive... I hadn't heard of them before but they are now the only ones to offer a BB cartridge for less than Blouch. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
lordchilly Posted June 23, 2013 Share Posted June 23, 2013 The turbo is in and so far....its seems nice. not going to full boost until i break it in. My question is that on the actuator, there is a screw hole, does that remain open? Link to comment Share on other sites More sharing options...
Adam393 Posted June 24, 2013 Author Share Posted June 24, 2013 That's just a vent, so you do not have to plug it Link to comment Share on other sites More sharing options...
V8Bait Posted June 24, 2013 Share Posted June 24, 2013 I just bought an adjustable actuator from them for my VF43 bnr68. 100$ shipped, which is about half price compared to Forge and AVO. Hopefully it will perform just as well. Link to comment Share on other sites More sharing options...
lordchilly Posted June 24, 2013 Share Posted June 24, 2013 I just bought an adjustable actuator from them for my VF43 bnr68. 100$ shipped, which is about half price compared to Forge and AVO. Hopefully it will perform just as well. Which spring did you acquire? I believe mine came with 1.0 bar Sent from my SGH-T999 using Tapatalk Link to comment Share on other sites More sharing options...
V8Bait Posted June 24, 2013 Share Posted June 24, 2013 Which spring did you acquire? I believe mine came with 1.0 bar Sent from my SGH-T999 using Tapatalk I picked the 1.2 bar which is about 17psi spring. I will be running about 21-22 psi so that should be fine. Link to comment Share on other sites More sharing options...
lordchilly Posted June 24, 2013 Share Posted June 24, 2013 I might do the same now..grab a 1.2bar, cause Im about 19psi. Link to comment Share on other sites More sharing options...
lordchilly Posted June 24, 2013 Share Posted June 24, 2013 i got a 10% coupon code for kinugawaturbo com kinugawa528069 exp 6/30 Link to comment Share on other sites More sharing options...
V8Bait Posted June 24, 2013 Share Posted June 24, 2013 I might do the same now..grab a 1.2bar, cause Im about 19psi. Yeah i think you would be alright with either but you might get better boost response with the 1.2. Link to comment Share on other sites More sharing options...
Drew888 Posted June 24, 2013 Share Posted June 24, 2013 The turbo is in and so far....its seems nice. not going to full boost until i break it in. My question is that on the actuator, there is a screw hole, does that remain open? Looking good! No need to break it in though. Just go get it tuned. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
V8Bait Posted June 29, 2013 Share Posted June 29, 2013 Well the actuator i purchased from Kinugawa does not fit my VF43 . Comes somewhat close but definitely wont fit. Link to comment Share on other sites More sharing options...
WaspGT Posted July 13, 2013 Share Posted July 13, 2013 If this has been previously stated i apologize, but are there any vendors on here that sell Kinugawa turbos? Link to comment Share on other sites More sharing options...
Adam393 Posted July 13, 2013 Author Share Posted July 13, 2013 I'm not aware of any vendors on here, or large ones like Autoplicity, carrying Kinugawa Link to comment Share on other sites More sharing options...
WaspGT Posted July 13, 2013 Share Posted July 13, 2013 You can the 20G TD06's right off of the Kinugawa site for $770 shipped. Thats killer. I thought i could cut corners and go with JM Turbo Technologies located in Alhambra CA... 20G was $400 shipped, absolutely beautiful, but the shaft had massive play??? I'm not puttting that sh!t in my car! Then they wanted to make me pay to ship it back to them? Yeah right, you send me a faulty piece thats on you! Pricks http://jmturbo.com/ Link to comment Share on other sites More sharing options...
lordchilly Posted July 13, 2013 Share Posted July 13, 2013 I think I have a coupon code for the kinugawa site. I'll get back when I get home. Sent from my SGH-T999 using Tapatalk Link to comment Share on other sites More sharing options...
WaspGT Posted July 13, 2013 Share Posted July 13, 2013 I think I have a coupon code for the kinugawa site. I'll get back when I get home. Sent from my SGH-T999 using Tapatalk That would be IDEAL Link to comment Share on other sites More sharing options...
