knock sensor on 95 legacy 2.2
Have a code for knock sensor comes up on obd2 check, problem is can't get bolt to come out of block, I know it will snap off if anymore torque is put on it. tried areokroil still wont budge. noticed thread boss in block under throttle body. Can it be bolted on there instead?
The knock sensor is held by only that one 10mm bolt through the center of the knock sensor. I've never had one so suck it broke, Subaru uses high graded bolts so just loosen it. I found that using a 1/4 size, 10mm swivel socket with a long extension. I actually have sets individual Matco swivel sockets for each size that work far better then a socket and the swivel. They hold their bend without flopping all over the place but if you don't have these sockets then the later would be the next best option.
ditto!!
what have you got to lose. if you bust the bolt you relocate the sensor. and you are replacing the sensor any way.
remove the bolt or bust it trying.
thanks for the info, had some body mounting bolts snap off(were easy to drill out and retap). weren't too sure of metric grade on the engine.this is a great forum,thanks to all you folks that contribute information.
The bolts are grade 5 equivalent but are coated with an electrically charged galvanic coating to prevent galvanic corrosion between aluminium and mild steel. The grade prevents over torque because if you do over torque the bolt it will break the piezo on the sensor..remember 14 lbs.
