What turbo to buy?
I have a 05 obxt with 154k on original turbo. I know its coming soon. So want to be prepared or do before. Plan on getting catless up and down pipes also. Dont need alot more power than i has now (family wagon). So should i go stock vf 40 or maybe the vf46? Thought id see what you guys thought. Ive seen rebuilt. Vf40 going for 600?
^^^^^^^^^^^^^^ vf52, you won't regret it, otherwise i can sell u a vf40, needs to be rebuilt, seen someone on ebay that rebuilds from $250-300, little/to no shaft play, seals i believe were leaking, has about 60,000k, no damage to shafts or anything like that.
BNR 16G. If you get a VF52 you really should also upgrade the injectors & fuel pump.
You can run the VF52 on stock fueling just as easily as the 16G. They're very similar. Both can gain a little from aftermarket fueling, but stock fueling is easily doable.
MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII
