05sleeper Posted April 21, 2013 Share Posted April 21, 2013 So I've only found one thread taking about this for the legacy gt but didn't find anything about fitment for our cars. My Perrin 3" inlet is coming up on 8 years old and I think it's starting to be the cause to some issues plus wouldn't mind replacing it anyways just to be safe. My Perrin inlet sits on top of the power steering pump and rests against the tgv housing asking to have a hole in it. Has anyone run one of these hard inlet pipes? Install is no biggie to me since I work on Subarus every day just would like something to fit better and not have to worry much about it. People talk about heat soak but on other forums they argue that it really didn't affect much with the hard inlet pipe. Thanks Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 21, 2013 Share Posted April 21, 2013 sub'd Link to comment Share on other sites More sharing options...
05sleeper Posted April 22, 2013 Author Share Posted April 22, 2013 Hers link to part http://scoobytuner.com/products/?vApplicationID=40&sfID1=356&sfID2=352&productID=2835#installationInfo Link to comment Share on other sites More sharing options...
05sleeper Posted April 22, 2013 Author Share Posted April 22, 2013 Bump for knowledge Link to comment Share on other sites More sharing options...
meadr86 Posted April 25, 2013 Share Posted April 25, 2013 I know people run the AP hard pipe on this forum cause they have commented on other threads... I too am researching this Link to comment Share on other sites More sharing options...
05sleeper Posted April 25, 2013 Author Share Posted April 25, 2013 well if you find anything out before i post anything else up here let me know!! Link to comment Share on other sites More sharing options...
mattg Posted April 25, 2013 Share Posted April 25, 2013 I have heard that installing a hard inlet requires the manifold being off. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 25, 2013 Share Posted April 25, 2013 I have heard that installing a hard inlet requires the manifold being off. A member told me to avoid the silicone style because they can collapse. So, risk it with a silicone + do not have to remove manifold or get a hard pipe + remove the manifold? Link to comment Share on other sites More sharing options...
mattg Posted April 25, 2013 Share Posted April 25, 2013 With any reinforced silicone inlet (which most are) collapse shouldn't be an issue. At least below 500WHP. A lot of people are running them with no problems of that sort. Link to comment Share on other sites More sharing options...
05sleeper Posted April 25, 2013 Author Share Posted April 25, 2013 I know the intake manifold has to come off I've done it a fair share of times so not that big of a deal to me I just want to know FITMENT of the pipe.. I have the perrin silicone and have had it on the car since 05 and think its about time to replace before it decides to tear a hole in it from resting against the tgv housing and on top of the powersteering pump Link to comment Share on other sites More sharing options...
mattg Posted April 25, 2013 Share Posted April 25, 2013 You'll have to do some searching. Probably a lot more info on nasioc. Link to comment Share on other sites More sharing options...
05sleeper Posted April 29, 2013 Author Share Posted April 29, 2013 Did some more research over on nasioc and looks like I will be getting the AMR inlet pipe in the next couple weeks if money picks up. Found that it does in fact clear the power steering pump and don't have to do tgv deletes (even though I already have). It also is different then the agency power BC it has another very slight bend after the 90° bend to clear better and easier install. The 3" Perrin I have is the older style and have had it on the car since 05 so I want to get the AMR to clear much better and not worry about any holes since it hits everything at the moment haha. Will give updates when installed. Link to comment Share on other sites More sharing options...
meadr86 Posted April 30, 2013 Share Posted April 30, 2013 05sleeper that sounds good to me, and it seems like the price difference is negligible. keep me updated as my perrin looks like sh**, and will most likely bite the dust very soon. Link to comment Share on other sites More sharing options...
Nuclear Posted November 23, 2019 Share Posted November 23, 2019 Did some more research over on nasioc and looks like I will be getting the AMR inlet pipe in the next couple weeks if money picks up. Found that it does in fact clear the power steering pump and don't have to do tgv deletes (even though I already have). It also is different then the agency power BC it has another very slight bend after the 90° bend to clear better and easier install. The 3" Perrin I have is the older style and have had it on the car since 05 so I want to get the AMR to clear much better and not worry about any holes since it hits everything at the moment haha. Will give updates when installed. How do you do with AMR inlet? Is everything went smooth=bolt on? Link to comment Share on other sites More sharing options...
grovlet Posted November 27, 2019 Share Posted November 27, 2019 How do you do with AMR inlet? Is everything went smooth=bolt on? You do realize this thread is 6 YEARS old correct - and 05Sleeper has been inactive for 2+ years - so don't expect much for response... Link to comment Share on other sites More sharing options...
