Oil in intake
For oil in the intake. Can clearly be seen when I pull the bov off and get burnt oil from exhaust on start up.
I replaced Pcv yesterday and cleaned tmic out. This am oil in the tmic.
Car runs strong otherwise.
What else could oil in intake be?
Welcome to the club, I've been a member for a while now. I've been meaning to get a Crawford AOS to see if it fixes the issue. Also just replaced my pcv valve again so we'll see if the old one was bad even tho it wasn't super old.
276hp/347tq On a DynoJet
Dyno Video - Had a big lean spot as you can tell in the second pull
  • I Donated
I've seen reports of engine failures with the Grimmspeed AOS. On hard right turns (like on a track), it sucks the oil out of the engine (through the oil filler tube) and into the intake. Probably not an issue unless you drive your car really hard, though.
That alarming. I wear my driver side tires at twice the rate of the passenger. So maybe I so corner hard.
AOS is a band aid for a bigger problem.
Get a compression test, then go from there.
Are you suggesting that everyone running higher boost getting blow by has bad rings?
I'm at a loss, considering this only came about after going stage2. Suggesting the rings cannot handle the extra boost without blow-by.
Share your wisdom sir :)
