JMLegacy Posted March 11, 2013 Share Posted March 11, 2013 So since no one can tell me what's causing the sound (via inspection), i'm going with what I know from a prev car, and what was discussed in another thread. I'm replacing my LCA bushings and strut mounts. I'm JDM, so I assume using the spec B strut mounts wont be a problem with my setup. Only problem is, i've changed to KYB, can I make up the spacer using washers underneath the bolts? http://www.fredbeansparts.com/subaru-legacy-spec-b-front-strut-mounts.html LCA Bushings:http://www.fredbeansparts.com/whiteline-front-inner-control-arm-bushing-kit.html Is this the right part? this is the part that normally goes bad right? I hope these are the polyurethane ones Link to comment Share on other sites More sharing options...
I Cannot Play Bass Posted March 11, 2013 Share Posted March 11, 2013 Before moving forward, I would suggest trying to tighten the end links and checking your sway bar bushings. A mere 1/9 turn on the endlinks finally solved my problems, but that was after replacing bushings and several months of trying to track it down. I cannot speak to about the strut mounts, but the bushing that usually tears on the lower control arm is found here: http://www.fredbeansparts.com/whiteline-legacy-gt-standard-anti-dive-kit.html Looking at the picture below, courtesy of Infamous, the bushing that I linked appears on the left. The bushing that you linked appears in the right in the middle: http://www.infamousperformance.net/media/02/a20791b135034f95afc7b7_m.jpg I figured that I would replace both while the control arms were off and have never looked back. Link to comment Share on other sites More sharing options...
JMLegacy Posted March 11, 2013 Author Share Posted March 11, 2013 I knew it that those LCA bushings looked weird ! When you say endlinks, where exactly are you talking/ Link to comment Share on other sites More sharing options...
